Originally Posted by
me just saying was just looking at replacing the battery in the gear 2. It is simple, open the back and remove the battery. the battery was on top of everything unlike the gear s2 wherd I had to remove the motherboard. No soldering :-) anyway it is your loss if you don't want to give it a try, though it is always a good excuse to get a new toy :-) I was seriously considering getting the new samsung watch that will be announced next week because I was also concerned about messing with the battery. Not anymore.
https://www.ifixit.com/Guide/Samsung...lacement/25170 Thanks for the research! I could see exactly where I would break it. The part where I "carefully remove the battery connection wire with the tip of the spudger tool". If you've done that 10 times it is easy. For me the first time will result in a broken contact with wire stuck in it.
Just as well because the nearest replacements I found in ebay are in China and won't get here before October. No replacements in Amazon. I bet the replacement batteries have been left discharged for 5 years minimum.
Throw away culture.
