I really like the Gear S2 right now. Coming from Android Wear (Moto 360), there are a few things I would like to have (not deal breakers) on the Gear S2; which is paired to my Note 5.
1. Once you dismiss the last notification, it will automatically return to the watchface. I'm not fond of that extra step of turning the bezel or pressing the home button.
Edit- It looks like it returns to the watchface after a short amount of time. Solved!
2. Google Now. S-voice does work...at least for me, but it's limited. I'm talking about allowing the Google Now app to be invoked by going to it and pressing it on the watch. I'm not talking about cards here either. I'm talking about the ability to say 'Okay Google' to ask questions. If there was a way this could happen, it would be killer.
3. Auto brightness ...I used this feature on my Moto 360 and really liked it. I often need to switch when going outdoors to indoors.
I also noticed that sometimes my S2 gets stuck on (meaning the screen doesn't turn off and 'always on' is turned off) and I have to restart it. I'm trying to figure out what's causing it...it doesn't happen all the time though. Anyone else?
Edit- Solved! It looks like it was a flashlight app I installed. It seems to force the display to stay on. I found this to be the case and when I manually killed the app, things were back to normal.
4. Since I don't code, I'm patiently waiting for a digital watchface that gives me the time, date, weather, and notifications. Just a request.
That's all I can think of for now. I really like this device! I hope Samsung supports it, like Google supports Android Wear.
