1. jrsharp70's Avatar
    Ok... am I imagining things, or do some of the lines/text on a dark background show a fuzzy haze around them? I'm looking at my watch face, and some areas the text is razor sharp, where other areas there is fuzziness around it.
    It shows up with the watch face and with text... but not evenly.
    When I take a screen shot, it isn't there on my phone.
    11-16-2015 08:48 PM
  2. Ittlebit's Avatar
    I have checked several of my watch faces and don't notice what you are describing, maybe it is the specific watch face that is causing the problem. Does it do it on more then one face?
    Note 4 with Gear S2 3G
    11-17-2015 01:18 AM
  3. jrsharp70's Avatar
    With every screen
    11-17-2015 05:07 AM
  4. Ittlebit's Avatar
    All my letters are crystal clear. Sorry, you may definitely have a problem with your watch. I guess you can try a reset and see if it goes away.
    11-17-2015 08:37 AM
  5. jrsharp70's Avatar
    I'll decide if I need to swap it out. I guess maybe just a screen defect. It doesn't really affect use though.
    11-17-2015 08:46 AM
  6. jrsharp70's Avatar
    I did a reset and restart of the phone and it went away... So weird.
    11-17-2015 05:03 PM
  1. Front Facing Camera In Low Light
    By TripleOne in forum Samsung Galaxy Note 5
    Last Post: 05-06-2017, 04:24 AM
  2. Camera Flash -- Is it NOT an LED flash light !?
    By evolvedsapien in forum Nexus 6P
    Last Post: 11-23-2015, 07:44 AM
  3. Replies: 1
    Last Post: 11-15-2015, 05:32 PM
  4. IPS Screen/Backlight issue/bleed!
    By mstrmind5 in forum Ask a Question
    Last Post: 11-15-2015, 04:35 PM
  5. Led light soft keys galaxy s6
    By Peter Starzynski in forum Ask a Question
    Last Post: 11-13-2015, 06:23 AM
