You can download Toggles from Samsung store for your watch. Then download Toggles gear from the regular play store for your phone. It gives you info about cellular strength, location on (or off), nfc on (or off) and battery level of the phone. Then you can control, brightness, sound, flashlight, data sync, etc of the phone from your watch. It's my favorite app. Only glitch for the s2 is if you shut your phone off and back on Toggles won't connect so you have to uninstall toggles gear from the phone and re-download it. Then it will work fine again. Really worth the trouble. Especially since I don't shut my phone off very often.
