Am I completely missing something here? Why can I not get my watch on our wifi network. It requires authentication. But if I make sure that bluetooth is enabled. It scans the network and I can see it. However if I try to connect it tells me authentication errors. But I can not find a single spot to add login or password or any authentication option. Only options to connect to wifi are AKA and SIM.. How the heck do I get this thing on a wifi network?? There is nothing anywhere on google about how to this. Am I the only one on the whole internet that owns one of these that can't connect my watch to a secure network?
http://downloadcenter.samsung.com/c...TT_SM-R730A_Gear-S2_EN_UM_TZ_OJ7_FINAL_AC.pdf
page 109
Settings
Wi-Fi
Activate the Wi-Fi feature to connect to a Wi-Fi network.
X On the Settings screen, tap Connections > Wi-Fi, and then tap the Wi-Fi switch to activate it.
Connecting to a Wi-Fi network
This feature is available when the Gear is not connected to the smartphone through Bluetooth.
1 On the Settings screen, tap Connections > Wi-Fi, and then tap the Wi-Fi switch to activate it.
2 Tap Wi-Fi networks > SCAN.
3 Select a network from the Wi-Fi networks list.
• Networks that require a password display a lock icon.
4 Tap CONNECT.
Once the Gear connects to a Wi-Fi network, the Gear reconnects to that network each time it is available without requiring a
password. To prevent the Gear connecting to the network automatically, select the network and then tap FORGET.
