1. Jack Marin's Avatar
    I see where others are having battery drain problems. I am not satisfied with the battery life and feel it was misrepresented.
    I have two email accounts and the gmail account does not send notifications to the s2. The gear software is correctly checked on the phone.
    I see where it is advised to to factory resets on the gear software and the s2 and to backup prior. How do I do that?
    12-28-2015 12:04 PM
  2. DeepSeaGoddess's Avatar
    On the phone in the gear app, there's an option for backup and restore. Click on it as it is likely taking a backup and it will show the last backup. Then, when I factory reset mine last night, I did that from the watch. Under settings, gear info, reset gear, then factory reset. Then, when it came back to setting up with the phone, I had the option to restore settings which I selected. It kept all my settings which was nice. So far after the factory reset last night, mine is back to normal battery life. I wonder if something didn't quite get updated correctly with the last update? It was right after it that I started to have problems.
    Do you have notifications on in the gear app for gmail? I do and it works just fine for me from my gmail account. I get the notifications on the watch.
    Good luck! I completely understand the battery frustrations!
    12-28-2015 12:53 PM
  1. Verizon Message + Problem, help?
    By JORENO in forum Verizon
    Last Post: 01-05-2016, 12:26 AM
  2. Have an S4 with custom ROM. What do I need to know to update?
    By drywater in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-28-2015, 12:20 PM
  3. Headphone jack problems on new Galaxy s6
    By 68lemans462 in forum Samsung Galaxy S6
    Last Post: 12-28-2015, 11:59 AM
  4. Why does my S4 drain when charging if used?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 12-28-2015, 11:51 AM
  5. Replies: 1
    Last Post: 12-28-2015, 11:18 AM
