Talderon
Very useful tips. Thank you.
One quick question: How do we know if the "4G radio" is turning off or not.....for me the default was "Auto" and I left it that way - also nothing else in the connections menu is turned on - (other than BT) ...so how do we know if 4G is turning off when its connected over BT...
Appreciate any help / comments. I am in trial period and will decide if I want to keep it based on few things....
The biggest issue for me right now : SVoice - pretty much useless....doesn't work, doesn't recognize many places on maps, its slow - its frustrating to keep hearing "I didn't recognize that - please say it again"..!! terrible.
When on the watch face, swipe down from the top. You will see a couple icons at the top.
If you see the BT icon, then you are connected via BT and Cell/Wi-Fi is turned OFF.
If you see Cell Signal and WiFi indicator, then you are not connected to your phone and your radio's are ON.
Setting the radio's to Auto is the best way to have full functionality and battery life.
Easiest way I can come up with on how to check.
Thanks!
