1. rld082982's Avatar
    They're bluetooth 4.1 but the s2 just scans for it and gives a "none found" message. Do I have to set something up within the phone app first?
    01-13-2016 10:29 AM
  2. rld082982's Avatar
    Seriously nobody has had this problem?
    01-14-2016 05:24 PM
  3. h2osun's Avatar
    I've paired just about everything with this watch, head phones, speakers car...no issues. When you tap on the Bluetooth setting while it is already on, it will make it visible. During that time, go through the pairing procedure with your other device. It does help to hold it close the first time. after that, should automatically pair when you turn on the other device.
    01-14-2016 10:26 PM
  4. rld082982's Avatar
    Sadly there is only 1 button on these headphones... to power them on/off
    01-15-2016 08:37 AM
  5. NoFaQ's Avatar
    I don't have the same headphones, but I have the MPOW Magneto. I have to ask, did you put the headphones in pairing mode before looking on the watch.
    If you don't put them in pairing mode, you will see "none found" all day long.
    01-21-2016 12:41 PM
  6. rld082982's Avatar
    There's only an off and on button, and volume up and down button.... I don't think there is a pairing option...
    01-21-2016 08:48 PM
  7. NoFaQ's Avatar
    If it's bluetooth headphones, there is always a pairing option. I may be able to help, though. My MPOW has a on/off, and a skip forward/back. If yours is like mine, you hold the on/off for a few seconds and it comes on, same for turning off. To put in pairing, start from powered off. Hold the power button for 10-15 seconds. If your headphones have voice prompts, it will say "Pairing". If not, the light to show power on will be blinking if in pairing mode. If it's a solid light, start over from a power off and hold the power on button until the lights start flashing. When that works, go to the watch and scan and pair again.
    tomget likes this.
    01-22-2016 08:26 AM
  8. rld082982's Avatar
    Oooooh ok, I will try this tonight! Thanks!
    01-22-2016 09:56 AM
  9. NoFaQ's Avatar
    Which model of the MPOW do you have?
    01-22-2016 12:23 PM
  10. rld082982's Avatar
    mpow cheetah
    01-22-2016 12:50 PM
  11. rld082982's Avatar
    holding the power down initiated the pairing... and the s2 instantly picked it up. thanks man!
    01-22-2016 06:27 PM
  12. 1237895641's Avatar
    I like QY11 sold by Vafee on amazon
    03-16-2016 10:52 PM
  13. Amochi013's Avatar
    Can you connect a Bluetooth Speaker with the watch??
    03-22-2016 09:50 AM
  14. tomget's Avatar
    Thanks for the Help..couldn't get my Mpower Headphones to pair..you're advice solved it
    11-07-2017 03:33 PM
  15. tomget's Avatar
    thx..had same problems with Mpower head phones..paired now..thx
    11-07-2017 03:34 PM
  1. Things You Don't Like About The 6P?
    By telrod11 in forum Nexus 6P
    Last Post: 02-04-2016, 07:50 AM
  2. I can't hear my phone ring, volume is up, its not in airplane mode?
    Last Post: 01-20-2016, 04:20 AM
  3. Replies: 2
    Last Post: 01-13-2016, 10:48 AM
  4. Replies: 0
    Last Post: 01-13-2016, 10:21 AM
  5. Screen mirroring Galaxy S5 to Acer laptop, how can I do it?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 01-13-2016, 10:20 AM
