1. Paisley's Avatar
    Hi all,
    Just ordered the watch. I will be using it with a moto x 2013 5.0 Android. What are some things I won't be able to do since i don't have a sammy that you know of?
    thanks.
    02-14-2016 09:17 PM
  2. slev's Avatar
    Only thing I know for sure you can't do is use the watch for making mobile payments. (Android Pay, Samsung Pay.) Other than that, there's no features you shouldn't have.
    Paisley likes this.
    02-15-2016 03:08 PM
  3. dcmarch's Avatar
    Can't do samsung pay with a Samsung phone so not much different
    Paisley likes this.
    02-16-2016 03:08 PM
  4. A0425A's Avatar
    There are some differences but I think they surround the use or lack there of a Samsung phone. So it's more about apps and features associated with apps that Samsung has built into TW. I'll give you an example and why I chose the S2 vs AW. In TW there is the ability to snooze calendar notifications via a swipe input. It's called scheduler. That's important to me. That doesn't exist in AOSP. Also while another poster did mention installing AW allows for reply to texts via Hangouts, I've seen other threads that indicate its not without issue. If you are using a Galaxy phone get the S2 . if you are using another phone buy the S2 and give it a try. But I suspect you'll head back to AW. I use Ant+ so I'll be on the Galaxy line until its no longer supported.
    02-17-2016 11:04 AM
  5. Paisley's Avatar
    Won't go to AW until they make the navigation more like this one. I'd just have no watch than AW. I'm all about making do though so could be fine but things like not being able to read a full text on the watch would be a bummer. And I read a few ppl say that was the case. : |. That could be a deal-killer. Also heard can only reject calls but can't accept. That I could live with.
    02-17-2016 07:29 PM
  1. Replies: 3
    Last Post: 10-12-2016, 01:23 PM
  2. How can I stop my battery draining?
    By The Madridista in forum Samsung Galaxy S6 edge+
    Last Post: 02-28-2016, 03:56 PM
  3. The latest leaked S7 Edge renders show a few more colors
    By deeb215 in forum Samsung Galaxy S7
    Last Post: 02-23-2016, 08:05 AM
  4. Why is my Samsung Galaxy Phone Going off frequently?
    Last Post: 02-14-2016, 09:30 PM
  5. New to Android with Samsung S4, can I get some help?
    By newbienow16 in forum Samsung Galaxy S4
    Last Post: 02-14-2016, 09:26 PM
