1. prubin's Avatar
    When I go to "Samsung Gear Apps" in Gear Manager I get the list of apps under Play Store, not the apps for the watch. I have uninstalled and reinstalled Gear Manager twice but it does not help. In reinstalling Gear Manager, I lost all my watch faces and apps, so all I have access to now are the stock faces and apps. Really would like some help.
    03-11-2016 01:18 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    You might need to clear the defaults on the Play Store in the app settings. That might give you the option to then select the Galaxy App store.
    Go to setting, applications, all apps, find the Play Store app and clear the defaults.
    prubin likes this.
    03-15-2016 10:17 AM
  3. prubin's Avatar
    That did it. Thanks. But I still cannot install apps. Anyone have any suggestions?
    03-15-2016 09:41 PM
  4. itguyjax8430's Avatar
    When you try to install an app what happens?
    03-16-2016 09:13 AM
  5. prubin's Avatar
    Actually I fixed it -- uninstalled Gear Manager, restarted phone, reinstalled, and it now works.
    03-16-2016 09:34 AM
  1. Replies: 8
    Last Post: 04-25-2016, 11:15 AM
  2. E-mail notifications not showing up on the Always On Display
    By dpham00 in forum Samsung Galaxy S7 edge
    Last Post: 04-05-2016, 10:28 PM
  3. Replies: 7
    Last Post: 03-14-2016, 07:14 PM
  4. SD Card works - not accessible via USB
    By Conrad Hall in forum Moto G (2014)
    Last Post: 03-12-2016, 12:22 AM
  5. My S Pen is working differently. How can I fix it?
    Last Post: 03-11-2016, 12:53 PM
