1. AC Question's Avatar
    So I have a Gear S2 and initially I had it installed on my Note 4 Edge and it worked awesome. Then I switched to the S7 Edge and installed my Gear S2, and I never really played with it. Last week I installed a Gear Circle Bluetooth headset and really both devices hardware-wise are working great.
    The problem is, when I go on the Samsung Gear App and I try to get apps for my watch, it goes to the Galaxy Apps store instead of the Gear S2 store. And when I try to install a watch face it tells me "This app is not available for your device. (UIbuYqN5qZ:2290:4002).
    Anybody come across this?
    03-12-2016 09:07 PM
  2. B. Diddy's Avatar
    Moved to the Gear S2 forum.
    03-13-2016 05:26 PM
  3. prubin's Avatar
    I have exactly the same problem and did not install a headset. I was on the phone with Samsung yesterday for over an hour and they could not fix it. They promised to call back within 48 hours; will keep you posted.
    03-14-2016 04:19 PM
  4. lowboydrvr's Avatar
    Did you try unpairing the headset, confirm you get to the Gear Apps and then re-pair the headset? I have both and have had no issues with my S6E+.
    03-15-2016 05:54 AM
  5. Ixz72's Avatar
    I'll try that. Thanks.
    03-17-2016 11:18 AM
  6. Thewordnerd's Avatar
    Similar problem here buddy. My gear s2 worked beautifully paired to my s5 but now that I got the s7 edge it doesn't load the gear apps through the gear manager. It only leads back to the regular galaxy store. It will only somewhat pair because I can control my music through my watch, change watch faces through my phone (only what's pre-installed since it won't load the store to download/buy more), and I can even receive my calls and emails.
    Basically it's just what you said about the .......:2290:4002 message, gear apps leading to gear store, and when you do tap on a featured face it'll say it's not for this device but I had the snoopy face when I had it paired to my s5 so I think it may be an s7 edge to gear s2 thing going on.
    03-23-2016 05:17 PM
  7. Ixz72's Avatar
    Gear app update this morning seemed to have fixed this problem.
    04-02-2016 09:44 AM
  1. Replies: 2
    Last Post: 08-31-2016, 11:59 PM
  2. Sleep Tracker App?
    By smooth4lyfe in forum Samsung Gear S2
    Last Post: 03-20-2016, 06:24 PM
  3. Google apps won't connect on home wifi on new S7 Edge
    By Drdwyer18 in forum General Help and How To
    Last Post: 03-17-2016, 11:53 PM
  4. How can i transfer data to print reports
    Last Post: 03-13-2016, 05:27 PM
  5. Tap Screen to Turn On
    By sjfwhite in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 08:14 AM
