1. techiegirl's Avatar
    I'm not sure if it's possible, but I'm hoping to connect my new Samsung watch (S2 Classic 4g) to AT&T Numbersync. My AT&T phone is an iPhone 6s Plus. My Samsung phone is my T-Mobile phone. The AT&T phone # is my main line and that's the # I want to ring on the watch. I know I can call forward, but I'd rather not do that.
    Whenever I log into AT&T to pair, it says "error in backend system."
    03-24-2016 12:27 PM
  2. Kyoshiro82's Avatar
    You can sync it via the myatt app or online. Log in to your AT&T account go to my plan and device features and find the watch. Then activate numbers sync in the list for the watch. It will see your phone as long as they have it set up right with the correct imei.
    03-25-2016 05:22 AM
  3. MJ Kubba's Avatar
    Did you get this thing resolved ? I have the same issue with LG Urbane 2,
    I called the support (611) and opened a case that didn't go anywhere!
    04-25-2016 08:31 PM
  4. alfredtv's Avatar
    Not a simple option, but it works for me. I setup the S2 watch on an android phone with the SIM in it. I had to configure everything to make it functional (weather, maps, etc).
    Once I confirmed NumberSync was working I shut down the phone and replaced my SIM in my iPhone. I can enable and disable numbersync from the watch with my iPhone.
    I do not get alerts on the watch when the phone is in proximity (as it does not have a BT connection) but I didn't get the watch to wear when I have the phone. So far it is working the way I want.
    I know Samsung released the Gear Manager for iOS, but read that it disables NumberSync!
    01-11-2017 03:37 PM
  5. afblangley's Avatar
    Using a cheap Android phone dedicated to remotely connecting with the S3 is probably the best way for iOS users to get maximal use from the watch. The phone doesn't even need a SIM card if it's connected to Wi-Fi. So it can sit on a shelf, never leaving the house. The only hiccup is caller ID, which can be addressed with NumberSync, Digits, or Google Voice.
    01-12-2017 01:16 AM
  1. Replies: 1
    Last Post: 03-24-2016, 01:52 PM
  2. My sons Galaxy S3 has lost its firmware please help?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 03-24-2016, 12:58 PM
  3. Replies: 1
    Last Post: 03-24-2016, 12:10 PM
  4. Resetting a Google Nexus 7 for a new user?
    By AC Question in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-24-2016, 12:09 PM
  5. Replies: 0
    Last Post: 03-24-2016, 11:50 AM
