1. cvnehring's Avatar
    So I have been battling with my gear s2 classic and I can't seem to get text messages on my gear. I tried factory reset and I use the native messages app on the galaxy s6. I have the notifications turned on the the gear app, and the watch is connected to bluethooth. Anyone know how to get notifications working?
    04-03-2016 12:50 AM
  2. lowboydrvr's Avatar
    What app are you using. I had trouble with Textra (wasn't receiving the notifications on the watch) and switch to Go SMS Pro and haven't had an issue since.
    04-06-2016 05:55 AM
  3. Mike-Mike's Avatar
    yeah, what app are you using? I stick to stock, but I have tried Textra and Messages+, and both received notifications like normal on the S2 Classic
    04-06-2016 08:40 AM
  4. Brittani Anzovino's Avatar
    If you want to use hangouts try to dl and install the android wear app on your phone. I didn't need to pair it with the watch but I then was able to even reply to hangout messages. Otherwise also check in the gear app, on your phone, the setting for receiving notifications if the phone is in use. That will have to be set so that it will still send notifications even if you are using your phone.
    04-06-2016 01:20 PM
  5. Dgedg13's Avatar
    Hi, have a look there, I just posted a solution that works.
    Regards
    don't get notifications | Samsung Gear S2
    04-25-2016 11:25 AM
  6. Gregory Washington's Avatar
    After experiencing the same problem, albeit 1 1/2 years later, the only solution that worked for me was deleting Samsung apps (Gear, Plugin, and Accessory Service from the phone, do a light reset of the watch, and installing a new messaging app (Pulse).
    11-02-2017 12:23 PM
  7. King_Boo's Avatar
    This may be a bit late but I was having the same problem seems the only way I could fix it was to deactivate At&T number sync then reactivate it. Hope this helps.
    12-16-2017 12:29 PM
  1. Replies: 2
    Last Post: 05-16-2016, 05:34 PM
  2. Android not recognising Bluetooth keyboard
    Last Post: 04-03-2016, 12:34 AM
  3. Gear s2 3g can't send messages
    Last Post: 04-03-2016, 12:29 AM
  4. Replies: 0
    Last Post: 04-02-2016, 11:36 PM
  5. Hard reset not resetting update history?
    Last Post: 04-02-2016, 10:28 PM
