1. maf113's Avatar
    Does anyone know how to turn off Auto Brightness on the Gear S2 3G Classic (Verizon)?
    04-19-2016 01:53 PM
  2. FitzAusTex's Avatar
    I don't have the 3g, but I don't think there is a way to turn it off on the non-3g. I just installed R720XXU2CPC5 that became available the other day, and now my auto brightness is jacked up. It is too dim much of the time, as settings 1 through 5 are the same level. But sometimes 1 through 5 act normally. Too soon to know for sure, but it seems as if Samsung changed it such that my S2 defaults to the dimness of level 1 in dark situations, even though it is still set to 4. Not pleased with this change.
    04-20-2016 10:57 AM
  3. maf113's Avatar
    That is the problem I am having. I checked with Verizon and Samsung and they all said it was normal operation. I do not like auto-brightness at all. I have it turned off on my phone and only use it as a switch to lower the brightness when in the car while it is dark out.
    04-20-2016 12:06 PM
  4. FitzAusTex's Avatar
    The S2 never had true auto brightness, but rather it would only go to full brightness in very bright situations (like outdoors), which I found very helpful/useful.
    04-20-2016 12:33 PM
  5. qdigga's Avatar
    Had the same problem here (among a multitude others). I normally keep my S2 Classic on like 2 or 3, but found that it would go to darkest level for 1-5 for no reason. Had to do a light reset on the watch and then reset it up on my phone. This fixed ALL of my problems (Light issues, Weather not working, spotty notifs). Only thing is, I have like 130+ watchfaces and the setup, restoring previous settings, took literally a few hours. Keep that watch on the charger while you do it...
    04-21-2016 04:18 PM
  6. maf113's Avatar
    Sorry but, it is my Friday and my brain is fried. Explain the re-sets you did. What/how do I do a "Light Reset" on the watch. and what did you reset on your phone? Did you uninstall the gear manager or do you mean you started like you just got the watch.
    04-21-2016 05:19 PM
  7. qdigga's Avatar
    To do a light reset on your watch go to>settings> gear info> reset gear> light reset. This will do a reset, then when you go into the gear manager and find the watch, it will slowly install EVERYTHING you had on the watch. Hope that helps.
    04-27-2016 04:40 PM
  1. Android Auto connection issues
    By Yinzer1 in forum Android Auto
    Last Post: 04-20-2016, 08:46 PM
  2. Replies: 2
    Last Post: 04-20-2016, 09:05 AM
  3. Now have a Very Bright Green Screen Showing up
    Last Post: 04-18-2016, 08:19 PM
  4. can i listen to radio in andriod auto while using maps
    Last Post: 04-18-2016, 01:34 PM
  5. why Auto rotation doesn't works in Samsung J7 ?
    Last Post: 04-18-2016, 05:27 AM
