1. PsychDoc's Avatar
    What would your recommendation(s) be?
    04-20-2016 05:29 AM
  2. NoFaQ's Avatar
    I've tried a few different ones. I keep going back to "Star Trek Watch" since it seems to use the least battery of the ones I've tried.
    I can't say it's the "best", but it's the best of what I've used. I can get about 36 hours on normal usage (Auto-3g, Wifi on, no auto HR, No NFC, connected to phone with BT). I get frequent notifications for work email, during work hours, and I use S-voice to send messages frequently.
    KoukiFC3S likes this.
    04-21-2016 08:14 AM
  3. Furious10's Avatar
    I love one called "Stickman"; simple and really long battery life. I am using one called "Alpha_Dark_Pro_12hour" at the moment. It has a lot a features but doesn't use much battery. I have the 3G (auto), Bluetooth turned on, wifi off and notifications on. Here is the "Stickman" ... https://www.facebook.com/gears2watch...8974147532569/
    04-21-2016 02:18 PM
  4. qdigga's Avatar
    There's a series of watchfaces called xClock and xWatch. I have most of the newer ones (like 15 or so). Many of them do require you to install a small app on your phone called ximatic gear service, but with that installed you can see watch battery, phone battery and weather on the face. With those series of watchfaces I get close to 2 days, while others like Gear O'Clock and Mr. Time series seem to drain MY S2 Classic a LOT faster....
    04-21-2016 03:12 PM
  1. Replies: 1
    Last Post: 04-20-2016, 09:45 AM
  2. Replies: 2
    Last Post: 04-20-2016, 04:11 AM
