02-23-2018 01:06 PM
56 123
tools
  1. AC Question's Avatar
    Hi All,
    I recently received a Gear S2 sport watch as a gift. For the first few days the battery would be at about 55-60% at night before putting it on the charger. Now, yesterday and today, the battery drained completely in about 5 hours from 100%. I don't remember making any changes or installing any apps, I had it pretty much set to default. Now I'm playing with it by turning the brightness down, wake on gesture off, wifi off, nfc off. I did a factory reset. Nothing seems to help. I can literally watch the battery meter tick down.
    What could be causing this?
    04-22-2016 12:22 PM
  2. baba_ganoush's Avatar
    I've had my classic for a few months and the battery would always last 2 days. These last few days though I'm having the same problems as you. I don't know if the recent update did this but I have not changed any settings. Glad to see I'm not the only one.
    04-24-2016 09:16 PM
  3. rodalfa's Avatar
    Same here. Reduced from 2 complete days to less than 12 hours... I believe also it is related to firmware update
    04-25-2016 04:09 PM
  4. ret18057's Avatar
    Glad I wasn't alone, I am trying out the S2, I also have a Moto360 (2015), and I was really disappointed I can't get through one day with the S2. After the latest update, the Moto lasts 2-3 days pretty easily. So I guess there's nothing I can do...
    04-28-2016 11:38 PM
  5. tstreete's Avatar
    The battery life you're getting does not seem normal. My bluetooth classic (R 732, non-3G) using the latest firmware (CPC5) is still typically above 50% after 18 hours of use. (That's with "always on" turned off, brightness at 50%, dark watch face.)
    If some (or all of you) have 3G watches, the battery life expectations are different and there are settings unique to that class of watch.
    04-29-2016 07:25 AM
  6. msgwolf's Avatar
    Good morning,
    I have the 3g version with verizon, I took mine off the charger 8:30 am Thursday and currently (Friday) at 11:30 am have 51% still. I am connected via blue tooth all the time and have gps on, mobile network set to autoswitch and wifi off. I have NFC off as well, I had to do a lite reset to get that to turn off, sounds like a common issue after the update.
    04-29-2016 10:39 AM
  7. Jguffey's Avatar
    What software version are you running on your Verizon 3g model?
    04-30-2016 01:40 PM
  8. Delirious D's Avatar
    Mine last a couple of days more tha 2. Its always connected to my phone . I only have certain notification going to it. I dont see the point of having app notifications that cant be answered. Just the classic BT version
    04-30-2016 03:30 PM
  9. rodalfa's Avatar
    Hi finally solved my problem. Looking at the watch logs I had a lot of lines with errors in contacts sync. Disabled all contacts to sync with smartwatch and deleted a lot of old contacts (I had more than 1000 contacts, reduced finally to 700), and now it returned to normal, two days of battery...
    05-07-2016 10:56 AM
  10. jneusch's Avatar
    I was having huge battery drain over the last week. I did a soft reset last night and it is working great today. 14 hours so far and 71% left. It's back to its normal self.
    05-07-2016 07:47 PM
  11. Jguffey's Avatar
    I'm having the same problem. I probably need to look at the contact sync. I have over 12k business contacts in my phone. I know android is not designed to handle that many contacts. But dosent seem to affect my huewai watch. The Huawei watch will easily have 50 percent left when my VZW s2 3g dies.
    05-07-2016 09:30 PM
  12. wboyce58's Avatar
    How do you disable the contact sync?
    05-08-2016 07:08 PM
  13. Jguffey's Avatar
    Not sure I would like to know also. I have done a reset and turned essentially everything off other than Bluetooth (3g, Nfc, heart rate, GPS, call forwarding, no apps installed, black stock face, etc.). Still dies on just a few hours . I had 1 day last week where I thought the problem was solved, but back to the same horrible battery life the next day. Looks like I'll be putting it on eBay soon.
    05-09-2016 10:48 AM
  14. haus's Avatar
    Came in here to say I'm having the same battery life problems on my Gear S2 since the most recent update (3g version, Verizon). I did a full reset last night to see if it would help, but it didn't. My watch has been off the charger for about an hour and it's at 80% right now (about 20 minutes of that was remote connection while I was out for a run).
    BT on, Mobile on, Wifi off, NFC off, Location was off until I went running (S-health turns it on), but even so, 20% in an hour isn't as good as it used to be.
    05-10-2016 10:29 AM
  15. haus's Avatar
    Can you elaborate on this process a bit? Viewing the watch logs and changing contacts sync?
    05-10-2016 10:30 AM
  16. rodalfa's Avatar
    The easy way: remove contacts access in Gear Plugin app in Android Permissions. Then you will not see who is calling you in the smartwatch. But probably battery returns to normal levels...
    05-10-2016 10:40 AM
  17. haus's Avatar
    I'm not willing to remove that level of functionality. But this is so weird - since my post, I changed Location from GPS + Wireless to just GPS, and it's now 90 minutes later and my battery is at 79%. So I've lost just 1% in over an hour.
    One other difference - my phone is closer to me than it was before, so I wonder if they changed something with the BT radio that makes it try to connect with more power when the phone is in the next room (vs. giving up and going into remote connect mode).
    05-10-2016 12:00 PM
  18. Jguffey's Avatar
    From my expirence I think the battery level lags a bit. I notice simular periods where it does not move, then it will drop 20 percent in an hour. Oddly yesterday I took it off the charger at 65 percent, 20 minutes later it was at 71 percent. That has only happened 1 time.
    05-10-2016 02:45 PM
  19. Maneesh Rai's Avatar
    SAME PROBLEM i AM FACING AND GETTING NO HELP. IF SOMEONE CAN HELP............
    05-12-2016 01:45 AM
  20. KahneFan's Avatar
    I changed Location from...
    What is location good for? I don't track runs or rides or anything, so is there any real reason I would care about location on my watch?
    05-12-2016 11:47 AM
  21. KahneFan's Avatar
    Looking at the watch logs...
    Where are the watch logs to review?
    05-12-2016 11:48 AM
  22. rodalfa's Avatar
    It is a bit complicated, you need to have sdb installed (it is included in samsung developer tools like gwd) and use it with debug option on in smartwatch
    05-12-2016 12:04 PM
  23. Maneesh Rai's Avatar
    The battery life reduces to 3-4 hrs if all permissions are granted to Gear app....
    05-20-2016 12:33 AM
  24. haus's Avatar
    So I think I figured out my issue. Every time I run, Gear S2 turns location on with GPS+Wireless, and when I'm done it stays on. Today I turned location off, started a manual run (instead of using the widget), and the watch asked if I wanted to use location services. This time I pressed "x" for no. Then I went back to the widget, started a run, stopped it, and noticed that location was still off. I'll test it tomorrow with a real run, but when I turn location off my battery lasts much longer.
    06-10-2016 06:42 PM
  25. Rose Lewis's Avatar
    My gear is crashing out in 2 hrs and Bestbuy and Samsung are being useless. Please walk us through this. I'd love to see those logs esp since I don't see where you can control contact syncs.
    06-11-2016 06:47 PM
56 123
  1. Replies: 2
    Last Post: 10-01-2016, 07:29 AM
  2. my battery says full but runs out after 2 hour's.
    Last Post: 04-23-2016, 01:27 AM
  3. huge battery drain while driving
    By dzstoys in forum Samsung Galaxy Note 5
    Last Post: 04-22-2016, 02:26 PM
  4. Battery life short and phone hot
    Last Post: 04-22-2016, 01:41 PM
  5. Replies: 1
    Last Post: 04-22-2016, 01:33 PM
