1. Fred Lucia's Avatar
    Had the watch S2 Classic since November and love it. All of a sudden the wrist gesture stopped working all else seems fine.
    I have shut off gesture rebooted watch and phone then turned it back on and still does not work.
    I did not do a full factory reset but whatever the other reset is called and it did not fix it.
    Has this happened to anyone else? Anybody have any ideas?
    05-16-2016 11:18 AM
  2. Deyan Donev's Avatar
    Sometimes mine stops working partially (lights up but doesn't go off when I put my hand down). Reboot fixes it.
    Does yours still count your steps? If not, maybe the accelerometer is broken, and you will have to return it. In any case I would recommend a full reset first...
    05-17-2016 03:20 AM
  3. Fred Lucia's Avatar
    Step counter is fine. Hate for full reset will have to re download watch faces but I have the day off so maybe
    05-18-2016 05:08 AM
  4. Fred Lucia's Avatar
    I don't belive it a factory reset fixed it and as I did a backup before I reset I was able to restore all.
    05-18-2016 06:24 AM
  1. HTC M7 setup wizard has stopped working after factory restore
    By DummySpit in forum HTC One Rooting, ROMs & Hacks
    Last Post: 05-16-2016, 04:41 PM
  2. How to stop G+ notifications in Gmail
    By TwitchyPuppy in forum LG G3
    Last Post: 05-16-2016, 11:08 AM
  3. Replies: 0
    Last Post: 05-16-2016, 10:10 AM
  4. Replies: 0
    Last Post: 05-16-2016, 03:28 AM
  5. Replies: 1
    Last Post: 05-16-2016, 01:15 AM
