1. llfloyd79's Avatar
    Not sure if this has been asked but does the Gear S2 work with the Nexus 6P?
    06-04-2016 03:00 PM
  2. FlyHigh365's Avatar
    It works with any android device over 5.0
    06-04-2016 03:17 PM
  3. tsparks1's Avatar
    Works great with my 6P, as FlyHigh365 mentioned works with anything over 5.0
    06-06-2016 06:18 AM
  4. FitzAusTex's Avatar
    I have a Nexus 5, and can no longer use Google Messenger on my Nexus if I want to reply to texts on my S2. Since 1.4, doesn't work any more. I get a "reply to text on phone message", rather than being able to reply directly from my S2. Just wanted to point this out if you're a Messenger user. I'm now using Textra, and that works well, and even better than Messenger on the S2, since all the quick replies I set up in the Gear app on my Nexus 5 are available on the S2, which was definitely not true when I used Messenger.
    06-06-2016 08:54 AM
  1. Anyone else unhappy with the audio quality of the Galaxy S7 Edge?
    By gwdetroit in forum Samsung Galaxy S7 edge
    Last Post: 09-07-2017, 10:14 PM
  2. Replies: 2
    Last Post: 06-07-2016, 02:43 PM
  3. huawei p9 or nexus 6p?
    By sportex in forum Ask a Question
    Last Post: 06-05-2016, 09:17 PM
  4. GEAR S2 Classic Charging
    By Forgewizard in forum Samsung Gear S2
    Last Post: 06-05-2016, 03:39 AM
  5. Problem with Google Contacts Sync
    Last Post: 06-04-2016, 06:52 PM
