1. AC Question's Avatar
    I am nothing short of astounded; Samsung seem to have created a lovely-sounding watch, the Gear S2 Classic, that requires a phone-based app to manage it. OK, fair enough, BUT I now find (after I have bought it) that for whatever reason, the specs required for Samsung Gear phone app are only for new, high end phones !
    The phone I have is barely a year old, a Grand Prime running Lollipop 5.0.2 with 1 GB ram, but the idiots at Samsung have made the app require NO LESS THAN 1.5GB....
    So I try to install Samsung Gear on my phone and it doesn't even show (as it is not listed as being compatible).
    300 euros paid for a brand new watch which does absolutely nothing !!!!!
    Samsung's reply when I chatted to a supposed tech support agent was, if you can believe it: "Return the watch".
    I will change my phone I guess in about six months.... but I watch to use the watch now.
    SO PLEASE, DOES ANYONE HAVE ANY FIX ? I don't care how, I would just like to use the watch that I have paid good money for.
    [Samsung have scored a serious own goal here.... to the extent that my no. 1 choice for technology from TVs, to monitors, to laptops, to phones..... (the list is quite long)... Is about to be drop kicked to bottom of the list. Or possibly removed from the list altogether.
    Anyone at Samsung brave enough to come back with real solution, not some ***** suggestion to return the device I have just bought ?
    Thanks
    06-13-2016 12:25 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sorry, but the official site does clearly state that it requires devices with at least 1.5 GB of RAM. Device Compatibility | Samsung Gear S2 - The Official Samsung Galaxy Site 1 GB of RAM is pretty small by today's standards--even if you were able to get it working, the experience would probably be pretty poor.
    dpham00 likes this.
    06-13-2016 10:18 PM
  3. timoto5's Avatar
    Thanks B.Diddy for the response.
    Just to say that NOWHERE on my research (and I did quite a lot before forking out some 300 euros on the S2 Classic) was there a warning anywhere that indicated there was a limitation that might completely prevent me from using this watch with a Samsung phone that is only about a year old.
    Your reference to a 'poor experience' is one thing, but currently I am not allowed to have any experience ! On a scale of 'nothing to good'.... I'd accept "poor" for now !
    So, with the greatest of respect, my question still stands: Is there any way that I can get a Samsung Galaxy Grand Prime paired with a Samsung Gear S2 watch ? Even if it is suboptimal I will happily accept that for now until I upgrade my phone in a few months.
    And I can bet that I will not be the only person out there who has a similar issue...... So a fix will be worth pursuing/identifying I am sure.
    Thanks
    06-14-2016 04:40 AM
  4. dpham00's Avatar
    Sorry to hear that. I did a quick Google search and found that it requires 1.5gb ram pretty quickly. If you weren't able to ascertain in your search that it requires 1.5gb ram, did you contact Samsung customer support?
    How can I connect my Samsung Gear S2 (Classic) with my Samsung Galaxy Grand Prime?-uploadfromtaptalk1465947824092.jpg
    06-14-2016 06:45 PM
  5. dpham00's Avatar
    Ok so, I had to look for a phone with less than 1.5gb ram which I had, which was difficult but then I remembered that I had a Verizon moto e 2nd gen with 1gb ram which I picked up for $10 sometime back. I backed up the gear apk and emailed it to myself and was able to side load it onto the Moto e 2nd gen.
    B. Diddy likes this.
    06-14-2016 07:03 PM
  6. ilovemypit's Avatar
    Here you go! check out this link. you can set your watch up without a phone by following these instructions. hope it helps! Setup a Samsung Galaxy Gear S2 Watch with No Phone - VisiHow
    02-02-2017 12:04 PM
  7. Shawn Hobbs1's Avatar
    Question, I got a gear s2 as a gift. How did well did the gear s2 work with the moto e?
    06-30-2017 01:59 PM
  1. Can I recover Galaxy S4 from a bootloop using TWRP Recovery?
    By tritty22 in forum General Help and How To
    Last Post: 06-14-2016, 07:48 AM
  2. How can I get multiple browsers to open per app? (Galaxy s7)
    By AC Question in forum Samsung Galaxy S7
    Last Post: 06-13-2016, 05:23 PM
  3. Why does my Samsung Galaxy Note 10.1 turn off and not stay on?
    By AC Question in forum Samsung Galaxy Note 10.1
    Last Post: 06-13-2016, 01:14 PM
  4. How do you or can you get a months history and print it?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 06-13-2016, 11:45 AM
  5. Galaxy as a microphone?
    Last Post: 06-13-2016, 11:40 AM
