1. draftpeppin's Avatar
    I'm finding that I have to force the wheel on the watch face more and more. I'm not sure if it's sweat and food getting stuck or just bad mechanicals. Anyone else having this? I wonder if Verizon would fix/replace it.
    06-26-2016 04:06 PM
  2. Deyan Donev's Avatar
    Wash it thoroughly with water. And stop dipping it in your jelly
    draftpeppin and priceslss like this.
    06-27-2016 07:03 AM
  3. draftpeppin's Avatar
    I would think water would be bad. Interesting! Thanks.
    06-28-2016 07:04 PM
  4. ndtemple417's Avatar
    Did this solve your issue just curious as mine can be difficult at times
    07-01-2016 09:59 AM
  5. ehosey2's Avatar
    I had a piece of sand in mine and it had a slight drag and made a sound when turning the bezel. After a couple of showers with it on the bezel is back to normal.
    Sent from my Samsung Galaxy Note 5.
    07-01-2016 10:27 AM
  6. johna22's Avatar
    knock on wood water shouldn't be a problem, shower every day with mine on
    07-01-2016 10:34 AM
  7. draftpeppin's Avatar
    Mine went back to normal before I tried the water. It has done this a few times. This had just been the most severe and longest lasting instance. I will try it if this happens again. Might have been sand as mentioned above.
    07-01-2016 04:32 PM
  8. Mr_Spencer's Avatar
    Mine only did that after my toddler decided to put it in his mouth. I'm guessing it was all the drool and whatever he might have eaten previously that made it stick. Lol
    Posted from my S7 Edge via the Android Central App
    07-01-2016 10:49 PM
  9. AIRSOFT907's Avatar
    Mine will still move, but it won't do anything on the screen, at one point of the bezel. Or it will go backwards. Any ideas, just got it today
    12-25-2017 05:38 PM
  10. pudingenak's Avatar
    Omg, i dipped it into the water and move the wheels for a minutes and it back!!! thank you!
    01-22-2020 12:38 AM
  1. When trying to text msg..get error msg.
    Last Post: 06-26-2016, 10:39 PM
  2. why my samsung tab 2 getting hot when charging
    Last Post: 06-26-2016, 10:14 PM
  3. Replies: 1
    Last Post: 06-26-2016, 09:55 PM
  4. how do i get my ripple effect back when opening my phone
    Last Post: 06-26-2016, 04:23 PM
  5. G4 overheated and is now stuck in boot loop
    By trashford in forum LG G4
    Last Post: 06-26-2016, 07:05 AM
