I just installed Samsung Pay on my Gear S2. I've not used it yet at a store. And as Samsung has mentioned, it is only NFC.
What phone are you using? I get the Samsung Pay beta link in the Gear app on my Note 4, but when I click it says app "not available on your device." (I'm guessing this will only work for phones that already can install samsung pay, that is, the more recent ones.) I have the classic bluetooth/wifi only S2.
Sammoblie said you also need to have updated to the latest software "value pack", so in gear manager under gear info check if there is a software update before trying to install Pay beta on the S2. Also not sure where you're at buy this is available in the US only right now.
Where do you get it only works with non 3g versions? That really makes no sense from Samsung's standpoint.
Sorry. The discussion is about the beta software. Currently the beta version is only available for non 3g watches.
Gotcha. Thanks for the clarification. My BT hasn't gotten the firmware upgrade yet so will have to wait for that I guess.
How is everyone getting this update?? I'm going into the settings menu of the Gear app, clicking "About Gear", then "Update Gear software" and it tells me the latest is already installed. What am I doing wrong?
