So I have had my Gear S2 since Christmas and I love it. However, earlier this year I discovered an update to the Gear Manager app that is very annoying. When I first install the app on my phone (A Motorola Droid Turbo 2) everything works perfectly. All the menus work upon install like the Notifications, app install, settings, etc. However after I get it setup, it will run a couple days and then I noticed that my notifications aren't coming through. I tried to go into the Samsung Gear app and click on the notifications option. It will flash for just a second and then go back to the main menu. In fact it does this for every option on that app except for the last one (Samsung Galaxy Apps) which works just fine. I can even install new watchfaces. But I can't make any changes to anything else.
Unless.....
I uninstall all the apps it installs (Gear manager, gear plugin, s health, etc) and then reinstall them. If I do that, I get one shot at setting everything up and it will work again for a while. But if I make a mistake (forget to select a notification I do want for example) I have to again start all over.
Does anyone have any clue what is going on with this crazy app?
Unless.....
