1. mominem's Avatar
    Just got a Gear S2, still trying to figure out how to work it.
    How can I get the calculator app set as a widget on the watch? It's one of the simple apps I use most and I can't figure out how to make it readily available. I can get to it by having the app shortcut as a widget, then selecting the apps icon then selecting the calculator.
    So far I'm liking the watch but still trying to figure out how to work it and best use it.
    08-02-2016 06:15 PM
  2. Matthew Acosta's Avatar
    You can't set it as a widget, although you can set the calculator as one of your first apps in the apps view
    08-09-2016 04:07 PM
  3. anon(238680)'s Avatar
    The manual is available electronically either from your carrier for a branded watch or from Samsung for a basic BT version. I'm sure that would help.
    08-09-2016 09:35 PM
  4. d_ray_84's Avatar
    I had the Samsung free calculator app on my s2 and had to factory reset when I upgraded to the Note 7 and now the calculator app isn't showing up in the store... Is it still there?
    08-22-2016 11:23 PM
  5. Jimmy Bernstein's Avatar
    I had the same experience. Had to buy it for $0.99 in app store.
    08-24-2016 06:50 AM
  6. Lennatron's Avatar
    I was just searching the forums for an answer to this exact issue.
    I upgraded to the Galaxy Note 7 and had to reset the Gear S2 in order to pair. The free Samsung Calculator app that came with the watch is now missing and isn't on the Galaxy Apps store.
    I'm very annoyed because the calculator was my most used app on my watch.
    08-24-2016 08:15 PM
  7. d_ray_84's Avatar
    Very unfortunate but now I'm glad that I'm not going crazy and I'm not the only one... I am highly disappointed though, looks like I'll have to just give up a dollar for the material calculator
    08-24-2016 09:50 PM
  8. d_ray_84's Avatar
    I also sent an email through the Help> Contact Us link in the Galaxy Apps application. I guess I'll update if they answer me.
    08-24-2016 10:02 PM
  9. Lennatron's Avatar
    Please keep us posted! Its not right that we have to pay for a calculator after months of having the Samsung one.
    08-25-2016 04:10 PM
  1. Question about the always on feature
    By Rmbrown1964 in forum Samsung Galaxy Note 7
    Last Post: 08-05-2016, 10:09 AM
  2. New Sprint update?? LS992ZV5?
    By Bhizzle1121 in forum LG G5
    Last Post: 08-05-2016, 01:58 AM
  3. Upgrade Vertu New Signature Touch to 6.0
    By kfehling in forum Android 6.0 Marshmallow
    Last Post: 08-03-2016, 12:45 PM
  4. Music playback errors on Galaxy S5 Neo after update
    Last Post: 08-02-2016, 09:11 PM
  5. Galaxy tab s2 - dragon quest iv problem
    Last Post: 08-02-2016, 02:53 PM
