1. bkeh's Avatar
    I just updated the Gear app and the "Usage since last fully charged" only lists one entry, Contacts, and says it has used 92%?
    Anyone else seen anything like this?
    Attached Thumbnails Gear App Update - Contacts using 92% of battery?-screenshot_20161101-184418.jpg
    11-01-2016 01:53 PM
  2. haus's Avatar
    How do you get to that screen? I got an update last night and when I go into Gear Manager, I can tap the battery usage section and it brings me to "About Gear" but I don't see anything about battery usage stats.
    11-01-2016 03:04 PM
  3. Sassenach25's Avatar
    A little late on this, but I'm also seeing a similar battery usage stat for the Contacts app. Have you found a reason why?
    11-22-2016 09:07 AM
  4. rdandy5875's Avatar
    When I tap on battery usage it works normally. I'm seeing a larger than usual contacts battery usage also since this last gear app update, 34%, Next is my watch face at 17%. I'm not seeing high drain though. Still over 70% full day use, 14 hours.
    On a good note about this update I have gotten every notification since the update. Mine was missing notifications randomly for a week prior.
    11-24-2016 08:57 PM
  5. Draftnik1's Avatar
    Seeing the same thing. High contacts app at 36%, but still have 49% battery remaining 15 hours later.
    12-08-2016 10:00 PM
  6. JRube's Avatar
    Yeah, battery life took a dump on mine too. I'm not running apps, the screen isn't always on, I've soft reset, I've hard reset, I've cleaned up my contacts list.... I can put my watch on before I go to work, and it needs a recharge before I go home. Contacts is using up 98% of my battery life. Seems like updates are breaking things.
    12-21-2016 06:19 PM
  1. Replies: 3
    Last Post: 01-07-2017, 03:03 PM
  2. Email notification broke with new Gear phone app
    By Polen in forum Samsung Gear S2
    Last Post: 12-05-2016, 10:15 AM
  3. Why is the Galaxy Tab full of Apps that don't exist?
    Last Post: 11-12-2016, 03:35 PM
  4. Audio out of sync on youtube on Samsung phone
    Last Post: 11-03-2016, 05:40 AM
  5. Replies: 1
    Last Post: 11-03-2016, 05:37 AM
