1. TJ Blackwood's Avatar
    j63holland likes this.
    11-02-2016 07:31 AM
  2. skatergirl's Avatar
    Welcome to Android Central. Tell me, do you keep the always on display turned on?
    11-02-2016 07:39 AM
  3. TJ Blackwood's Avatar
    No, that's one thing I didn't mention, I keep the always on display off, cause that will also make the battery died faster.
    skatergirl likes this.
    11-02-2016 12:04 PM
  4. skatergirl's Avatar
    Yes, I have turned off the always on as well. I wish I did not have to, but it does drain the battery very quickly.
    11-03-2016 07:59 AM
  5. TJ Blackwood's Avatar
    Honestly I prefer it off, especially at night when it tend to do me if it turns on, and the motion tracking is the case Lights up when I need to look at it.
    11-07-2016 07:21 PM
  1. Replies: 3
    Last Post: 11-02-2016, 07:45 PM
  2. Can i remove battery limitation on samsung note 7 update?
    By Stephen Andi Halim in forum Samsung Galaxy Note 7
    Last Post: 11-02-2016, 10:24 AM
  3. Replies: 1
    Last Post: 11-02-2016, 06:46 AM
  4. How do i get the correct tempeture
    Last Post: 11-02-2016, 06:39 AM
  5. unable to start galaxy s5
    Last Post: 11-02-2016, 06:17 AM
