1. AC Question's Avatar
    I have charged in charge that connector that comes with it the way it will not charge it will not show anything brand ne
    05-16-2017 01:22 AM
  2. ratsttam's Avatar
    There are a couple things to check. First is that you're using the wall plug that came with the charging dock, and that is all connected properly. The light should flash red/green for a second when it's first plugged in. Then set the watch on the dock. The light should be red until it's fully charged. If that's not happening, than you've likely got a defective unit and should return it to where you purchased it from for an exchange.
    05-20-2017 06:53 PM
  3. aokusman1's Avatar
    A little background would be helpful. Is it new, was it charging before etc.
    05-22-2017 12:04 PM
  1. Replies: 3
    Last Post: 05-16-2017, 11:53 PM
  2. Replies: 1
    Last Post: 05-16-2017, 10:20 AM
  3. I forget my punk of Sim
    Last Post: 05-16-2017, 12:57 AM
  4. how do I get a hacker off my Alcatel one touch
  5. Link to live event @ 2AM EDT on 5/16
    By BigDinCA in forum HTC U11
    Last Post: 05-16-2017, 12:48 AM
