1. AndroiDudeJ's Avatar
    Both seem to work well together.
    However, I don't wear the S2 every day.
    Before I had the watch S-Health worked independently quite well.
    Now it won't work at all if the watch is disconnected.
    Is there a workaround that can be done without unpairing the watch?
    Thank you, in advance.
    B
    08-11-2017 11:17 PM
  2. mlblack16's Avatar
    make sure you're running the latest version of Samsung health. My phone keeps track of its own steps unless I tell it to sync with gear S2, but it seems to have started this through Bixby.
    08-14-2017 05:04 PM
  3. AndroiDudeJ's Avatar
    Hmm
    OK.
    How do you tell it to sync with your gear, or, otherwise, not sync with your gear?
    08-17-2017 03:38 AM
  4. mlblack16's Avatar
    you can open S health and see if the steps match your gear S2. Also, it will say "last synced...and then day/time" I believe.
    08-20-2017 04:29 PM
  5. PAC757's Avatar
    I have a work phone, personal phone(neither one a Samsung phone) and a Gear s2, all 3 are always a little off even after syncing the Samsung Health app. I have noticed since getting my S2 that the Samsung Health app on the connected phone is keeping my phone awake a lot more its always the highest battery consumption app now.
    08-23-2017 05:40 AM
  1. Samsung Note FE - Caller ID not showing
    By NeilHK in forum General Help and How To
    Last Post: 08-14-2017, 11:07 PM
  2. Samsung Galaxy J3 Eclipse POP3 Sync fouled?
    Last Post: 08-11-2017, 10:49 PM
  3. My samsung has no mike button to push
    Last Post: 08-11-2017, 10:02 PM
  4. Replies: 0
    Last Post: 08-11-2017, 09:59 PM
