    Do anyone can help me? I have a black spot or dot on the edge of the screen of my Samsung Gear S2. What is that? Do I have to replace the screen or what should I do?
    08-11-2018 03:28 PM
  2. B. Diddy's Avatar
    I moved this to the Gear S2 forum for more specific traffic.
    08-11-2018 05:37 PM
  3. Rukbat's Avatar
    It sounds like a dead pixel. If you can't live with it, and it's not under warranty (or if it is and Samsung won't replace it), that's what you'll have to do - have the screen replaced. (I wouldn't recommend doing it yourself.)
    08-12-2018 03:31 PM
  1. Replies: 3
    Last Post: 08-18-2018, 07:42 AM
  2. Why isnt my notification bar coming down😕
    Last Post: 08-11-2018, 05:38 PM
  3. Why my callers can't hear me
    Last Post: 08-11-2018, 04:37 PM
  4. What are the pop up notifications that come up on the top of the phone called??
    Last Post: 08-11-2018, 03:49 PM
  5. Deleted my os help
    Last Post: 08-11-2018, 02:36 PM
