I recently purchased a used S2 and have noticed the battery drains after just a few hours. Through the gear app on my phone, Samsung Health and Watch faces use the most battery. I have gone through some other forums already, but there doesn't appear to be an exact fix, nor does it look like people are seeing these two apps cause the problem.
I have deleted unused watch faces and apps, turned off WiFi, mobile network, and NFC(watch only connected to phone via Bluetooth)
Under the Samsung health settings, I have turned off all workout detection, and set measure heart rate to every hour.
Brightness at 5, and auto low brightness is on.
Some of these settings were applied AFTER I did a hard reset of the watch (using the buttons and using recovery mode). Some of these settings were already turned on before I reset the device.
Does anyone have any suggestions? Am I missing something? Does the battery simply need to be replaced?
Any input would be greatly appreciated!
