1. JayinKy's Avatar
    I have a Gear S3, a note 5 and love them both. I have two issues that irritate me. Both are related to messaging.
    1. I want to use Textra or similar for messaging. I do not like the stock app. When I set Textra as the default app on my phone my Gear S3 tells me that its unable to receive messages and to change the default messaging app to messages. Doing so resolves the issue but then I am back to using the stock app. I am sure others use Textra and other apps than just the stock app with the Gear S3.
    2. My Gear S3 is the LTE version and every time I go solo without my phone, The messaging app on my watch downloads all the messages I have had since the last time I was away from my phone and marks them as unread instead just the new ones going forward. I have to acknowledge each of those.
    Any help would be appreciated.
    12-28-2016 03:25 PM
  2. Bob31464's Avatar
    I have the same issues as you, I can only help with the 1st one. Sorry.
    I use Handcent for texting and when I get the message you described, I hit the x and it works fine. I haven't been able to find out how to stop it all together yet.
    The 2nd issue drives me nuts. Hopefully some has figured this out.
    12-28-2016 03:32 PM
  3. Paul Paradis's Avatar
    I use signal and gear notification extender. I don't get old messages again. I think that's in the settings.
    12-28-2016 07:45 PM
  4. JayinKy's Avatar
    Thanks for your help. It helped. I never tried cancelling the message.
    12-29-2016 07:37 AM
  5. JayinKy's Avatar
    This sounds promising but I can not find anything on sign as long and gear notification extender.
    Is the settings on the Samsung phone app or on the watch?
    I searched for apps in Android and Galaxy app stores. I even Googled it. I can find no reference to it.
    12-29-2016 07:41 AM
  6. crawfpm's Avatar
    I use Textra and so far, have some success. I turn off notifications in the Gear app for the stock Messaging app. I turn ON notifications for Textra. On watch, I get Textra notifications and even can reply to them. I can not compose a new message, only reply to one I get (I have asked Textra a couple times to produce a Textra app for the watch, maybe others here can also request it). So far, all my text messages get through to my watch.
    12-29-2016 09:54 AM
  7. Paul Paradis's Avatar
    I think it's the dismiss dead notification setting in the GNE app.
    12-29-2016 09:30 PM
  8. creekwater1482's Avatar
    I use Textra and it works fine for notifications and responding to them as well.
    12-30-2016 01:21 PM
  9. JayinKy's Avatar
    I have gotten Textra to work well now. Thank you for your help.
    Othyer than using data is there any drawbacks to running just LTE and disabling bluetooth?
    jhsumd#AC likes this.
    12-30-2016 03:27 PM
  10. anon(9228075)'s Avatar
    How have you gotten it to work?
    12-30-2016 06:14 PM
  11. afblangley's Avatar
    From what I've seen, there is nothing that can be done with BT, that can't also be done via remote connection. It may use more battery life, but it's more stable.
    12-31-2016 06:45 PM
  12. mvsmith's Avatar
    I have so many problems with MMS everyday. Any extra messages wouldn't show if I didn't check them. No incoming messages showed in watch app history. I've heard of stand alone mode and updating date and time in settings fixes it. No pictures were showing too. But I have the T-Mobile variant and don't like the sim line I have on watch.
    Using the digits beta with the pixel xl and it's perfect. Any and all messages now come into the watch with the entire message history and SMS pictures. They sync to my Google messenger default app and digits app too. AT&T has something similar but I recommend trying number sync.
    Also there was an update recently which shows multiple messages in the notification window. Samsung is still improving the watch which I love.
    12-31-2016 07:32 PM
  13. dshrum84's Avatar
    I started with a BT connection all the time and was getting 72 hrs on the watch battery once it stabilized but my phone battery was getting murdered. After starting the T-Mo Digits beta I've gone to using the remote connection via LTE and it works better overall for me. The watch has gotten to 60-72 hours and my phone has returned to normal.
    01-01-2017 12:07 AM
  14. Jimktao's Avatar
    Yes I would like to know how you got it working, i have same issue and cant get it to allow me to reply either.
    Thanks
    Jim
    01-30-2017 11:05 AM
  15. ejohnnyk's Avatar
    I have the second issue and it drives me crazy!
    02-03-2018 06:29 PM
  16. jgreg02's Avatar
    My phone is a BlackBerry Priv with BlackBerry apps and I don't have either of these problems. To be fair. I have limited notifications for most of the apps and I don't do much texting, just email.
    02-04-2018 05:18 AM
  17. anon(463177)'s Avatar
    Its all in the setup. I have Digits from TMob and that works pretty well but I still need to NOT set Remote Connect in Gear App and I keep my watch Wifi ON and Mobile Connection to Auto. And that works only when my watch shows Connected Remotely on the pull down screen. This seems to work but I soft reset the watch (turn on-off) every day when I put it on just to make sure there aren't any glitches.
    02-06-2018 09:26 AM
  18. michail71's Avatar
    I just swapped out for a LTE version today and #2 got me while my phone was rebooting.
    To make it worse I was replying to a text on the watch and #1 happened when the phone came back. It wiped out the response I had been working on.
    It's hard to give up Textra.
    When I had a V20 phone the messaging on the watch didn't work unless you directly reponded to a notification. That seems preferable to this behavior.
    02-18-2018 09:57 PM
  19. michail71's Avatar
    I gave in and went to Messenger.
    But no more #2 .
    Although Messenger isn't too bad. It's on par with Textra with some features but has fewer UI customizations.
    02-19-2018 01:53 PM
  20. SPR70NOVA's Avatar
    There is a new app called Textra which solved everything and now I can get my notifications on my S3. Make sure you set it as your default app. It is free and works great.
    03-14-2018 05:53 PM
  21. MooseKnuckeChuck's Avatar
    Would I be wrong to think that My Android Messages (google) text app would work with my phone? It doesn't and I do not want to revert back to stock. Anyone have a work around? Kinda disappointed because I have never had to worry about this with Android/Samsung
    07-20-2018 06:26 PM
  1. Variant system version message on htc m9
    By razigul in forum HTC One M9
    Last Post: 08-22-2018, 07:31 PM
  2. Gear s3 frontier Facebook connection issues.
    By adammale73 in forum Samsung Gear S3
    Last Post: 04-11-2017, 10:20 AM
  3. Replies: 0
    Last Post: 12-28-2016, 01:22 PM
  4. S Health / Gear Fit 2 resting Heart rate
    By Phill1986 in forum General Help and How To
  5. How do I stop cb text messages
    Last Post: 12-28-2016, 12:17 PM
