Hello, a few problems of various inconvenience I've encountered. Any recommended solutions are appreciated:
Spotify - Will not seamlessly transition from WiFi to LTE and vice-versa. Stops playing and displays an error message I've needed to open the app, enter settings and switch the streaming Modes.
Spotify is a battery vacuum! I doubt there is a solution here.
Watch went in to cool down mode 3 times while sitting in a coffee shop about 6ft from a fireplace. Closes all apps and disconnects headset. Is this concerning for warm weather runs, rides, climbs etc?
The data in the weather, altitude and barometer doesn't not appear to auto update. I've been drilling down into the apps and performing a manual refresh in order to obtain accurate information. Any way to auto refresh? (not an app update issue)
Beta - I understand light watch faces use more battery power than dark faces.
Thanks!
Thanks!
