1. sammkko's Avatar
    Has anyone been successful connecting S3 Gear to Wi-Fi with WPA2-PSK security?
    I have tried both WPS button on router and PIN code method and entering the WLAN password manually, but it won't connect for some reason. My router is D-Link DIR-645. I have disabled Bluetooth in the settings so that it won't use connection via phone.
    I'm trying to get Gear S3 connected to Tizen Studio, the instructions say to disable Bluetooth and connect to WLAN to get Gear S3 on the same network.
    01-19-2017 01:13 PM
  2. Ntchwaidumela's Avatar
    I just connected to my home wifi with no problem.
    01-20-2017 01:08 AM
  1. Why I cant move anything with the 'My Files' app?
    By skymx in forum Ask a Question
    Last Post: 01-19-2017, 08:11 PM
  2. Replies: 1
    Last Post: 01-19-2017, 03:50 PM
  3. Help connecting 360 wired controller
    Last Post: 01-19-2017, 12:32 PM
  4. Any android dual phone with specs similar to redmi 3s prime
    Last Post: 01-19-2017, 12:31 PM
  5. Disoriented front camera with vertical moving lines?
    Last Post: 01-19-2017, 11:49 AM
