1. raziel's Avatar
    Hey Everyone
    I have an S3 Frontier and US Unlocked s8+ both from Best Buy and have been at my wits end trying to get Samsung Pay to work on the damn watch. It works fine on the phone.
    However, when I try to set Pay up to work on the watch, it keeps telling me to sign into Samsung Lay on the phone. When I go to the Gear app under settings, Samsung Pay is nowhere to be found. I've been reading the forums and it seems there are issues with international versions not working with other regions. However in my case, both devices are US.
    Did Samsung leave out Samsung Pay out for S3 users with the unlocked phones? This is really frustrating!
    06-11-2017 09:08 AM
  2. Ca_lvn's Avatar
    I a bit confused here, but the SP is found in Info not settings on the gear app, I have a unlocked S7 with the gear S3 and it works perfectly, I'm sure there is sothing simple your overlooking here
    Hopefully you have installed this app from the play store
    06-11-2017 10:15 AM
  3. fernandez21's Avatar
    It should be in your gear app
    06-11-2017 07:00 PM
  4. raziel's Avatar
    Nope Samsung Pay is missing . Even with the new June 1 security update that just rolled out. Again I have the unlocked US version and US Gear S3.
    Other users on Reddit have reported the same thing.
    06-12-2017 10:39 AM
  5. Metatrhot's Avatar
    No entiendo. Puedes traducir a español?
    06-13-2017 02:28 PM
  6. Metatrhot's Avatar
    Hola. Por favor, traducción al español. Gracias.
    06-13-2017 02:33 PM
  7. raziel's Avatar
    Samsung Pay On US Gear S3 and US Unlocked S8+ Not working-dckfl1duqaaf3vj.jpg
    Got this from Samsung... Total BS. Only works with Carrier devices???
    06-14-2017 02:03 AM
  8. bmanzella527's Avatar
    I have the same problem.
    06-15-2017 03:47 PM
  9. Jaycemiskel's Avatar
    Another reason to not buy their carrier unlocked phones.
    06-15-2017 11:21 PM
  10. Ca_lvn's Avatar
    I have a carrier unlocked phone S7 and SP and anything thing else works great
    06-16-2017 08:08 AM
  11. raziel's Avatar
    I'm talking about the S8 not S7
    06-16-2017 08:17 AM
  12. thomasbihn's Avatar
    Don't bother trying to set up Pay on your S3. After the FOURTH time having to reload my cards on the Gear Pay, I just gave up. It's a gimmick that doesn't work and is more trouble than it's worth.
    I should clarify...it works when the cards aren't spontaneously removed.
    06-17-2017 07:43 AM
  13. afblangley's Avatar
    I've had no problems (using an LG or cheap Samsung phone) with S Pay. It's my favorite feature on the S3. I almost never use cash, so I typically have 100+ transactions per month. It works 95% of the time, I rarely need to use a physical card. No other watch has this capability.
    11B1P likes this.
    06-17-2017 11:03 PM
  14. ClintRo's Avatar
    No issues with mine being removed. Unless you reset the watch.
    06-19-2017 07:36 AM
  15. raziel's Avatar
    I found that this solution works, from the XDA Forums.
    https://forum.xda-developers.com/sho...&postcount=188
    I was able to get Samsung Pay partially working on the watch
    I downloaded Samsung Pay For Gear Plug In
    Installed and opened app
    Watch Samsung Pay launches on phone and trys to install a update but fails
    On the watch side when holding back button to launch Samsung Pay says A new version avalible Samsung Pay must be updated to continue
    Then says update in progress on phone but there's no update happening..
    I'm still trying a few things to see if I can get it to work
    Edit: I got spay for gears3 to work
    Step1: Download/install but don't open this app
    https://drive.google.com/file/d/0B94...w?usp=drivesdk
    Step2: Download/install but don't open this app
    Step3: Launch Samsung Pay on Watch
    Follow the instructions it will then update Samsung Pay for Gear and install successfully
    Step4: Launch Samsung Pay on Watch it should ask you to setup your cards
    Step5: Uninstall Samsung Pay (not the gear version)
    Then reinstall from play store and update
    Profit!!!!
    Note I did this on a fresh install on both the watch and phone
    Also I set phone up via LTE and not WiFi because you need to tell phone to not install samsung pay when that option comes up during setup...
    Just remember to use the links here: https://forum.xda-developers.com/sho...&postcount=188
    And make sure you turn off Wifi and not to update during initial setup!!!
    06-20-2017 11:40 PM
  1. How do I turn off Auto-Rotation on my Android Wear 2.0 watch??
    By OttawaMan in forum Android Wear / Wear OS
    Last Post: 01-26-2018, 04:33 PM
  2. Replies: 1
    Last Post: 06-11-2017, 11:07 AM
  3. Replies: 1
    Last Post: 06-11-2017, 10:40 AM
  4. Replies: 1
    Last Post: 06-11-2017, 09:10 AM
  5. Replies: 0
    Last Post: 06-11-2017, 08:36 AM
