I have two gear S3 watches, I can pair both to my S8 plus. The problem is setting up Samsung pay to use and work with two different Gear watches on the same phone, and use the same debit card. 1) both watches are to use the same debit cards. 2) One watch ("A") is active and linked to the phone. 3) setup the debit card on the phone for watch "A" using Samsung pay--all is fine to this point. On the watch SP works fine.
Now the problem: Turn off watch "A" and turn on watch "B", link "B" to the phone, proceed to setup SP. The first thing that happens is the previous working debit card is deleted and I,m prompted to re-setup the same debit card that was deleted. Now it's working for phone"B" just fine. Samsung Pay (SP) no longer works on phone "A" and will need to be setup again. Samsung Pay can't work with two gear S3 watches on the same phone. SP can only have one setup per phone, and each time you turn on a 2nd gear S3 watch, the exsisting SP setup is deleted. Why would anyone have a 2nd Gear S3 watch which will not be able to function correctly.
How does one setup two Gear S3 watches to work with Samsung Pay on the same phone? This is a MAJOR PROBLEM and needs to be addressed.
