1. DLW3555's Avatar
    After using a Fitbit for 3 yrs I made the switch to the new Galaxy S3 Gear. There are a lot of features I like .. but the lack of direct integration between the S3 Gear and Myfitnesspal has me questioning my switch.
    Some have had a little luck connecting through other apps, though it tends to be "off and on" connectivity. You would think two large companies like this could work out a "working integration".
    Anyone heard of any progress in a working connection?
    07-06-2017 02:05 PM
  2. anon(238680)'s Avatar
    Mod Note: Thread moved for better visibility.
    07-06-2017 02:33 PM
  3. jpieri4's Avatar
    My Gear 3 syncs just fine with it. Gear gives MyFitnessPal the steps and MyFitnessPalpal gives the Gear the calories.
    07-06-2017 03:33 PM
  4. sforsyth01's Avatar
    The Gear S2 & S3 support MyFitnessPal and have an app for the watch in the Galaxy Apps Store.
    07-06-2017 07:22 PM
  5. johnmcc0710's Avatar
    I cannot get my S3 to sync steps with MyFitnessPal. is there another app I need? I add food but manually have to add exercise. my Fitbit stopped syncing steps too. I still use the One
    07-07-2017 10:03 PM
  6. 11B1P's Avatar
    connect the two through samsung health and vice versa
    07-07-2017 11:45 PM
  7. johnmcc0710's Avatar
    that is exactly what I have done.it syncs food but not steps.
    07-07-2017 11:50 PM
  8. 11B1P's Avatar
    Have you opened Samsung Health on your phone and waited for the data from your Gear S3 to sync to your phone? Then open the MFP app on your phone and give it a few seconds to sync. In SH, have you set the app to track your steps via the S3?
    07-08-2017 11:35 AM
  9. johnmcc0710's Avatar
    Yes I have done all of that. Food and water sync but steps. I have my Fit Bit One connected and that doesn't sync either. I will keep playing with it.
    Thanks
    07-08-2017 08:05 PM
  10. haganjeff's Avatar
    My Gear Fit 2 with S - Health is not syncing steps to My Fitness Pal as well. Saw where some other people were complaining about it also.
    07-13-2017 05:24 PM
  11. johnmcc0710's Avatar
    The error I get when I go to steps is "We were unable to connect to the server to synchronize. I enter them manually from Samsung Health at the end of the day.0
    I don't know what the work around is. Every sees each other in both apps.
    07-14-2017 08:18 PM
  12. cvflowe's Avatar
    I use Endomondo and they all sync fine.
    07-22-2017 09:33 AM
  13. cricenog's Avatar
    I use UA Record for steps and workout as I like the workout tracking, but I've had issues with the step sync, for some reason they never match the Samsung Health steps, and often I have to disconnect and reconnect to have anything sync at all, does My Fitness Pal work better? Anyone had similar issues?
    Thanks,
    07-23-2017 12:15 PM
  14. Barney Lerten's Avatar
    MyFitnessPal Troubleshooting has a page with bug lists and https://myfitnesspal.desk.com/custom...ation-partners it does indicate a problem with syncing steps from S-Health. Frustratingly, on my new S3 Classic, it WORKED and I got a calorie adjustment Friday - but not Saturday! Not sure I changed anything - I've tried to expunge the old FitBit app from before my new watch from my new phone, my laptop etc. - turned on all the sync/permissions stuff. But I'd just live with the bug if it didn't work one day, not the next! Other than that, I love the watch - I get so much work email on it, I have to charge it every night but who cares - it's easy and I do the same with my phone;-)
    07-30-2017 12:28 PM
  1. Will the Tab s3 go down in price more of have smaller version?
    By Blues Fan in forum Samsung Galaxy Tab S3
    Last Post: 07-18-2017, 08:56 PM
  2. Update available with no option to download
    Last Post: 07-06-2017, 01:40 PM
  3. Activating Activity Reminder in S Health with Note 5
    Last Post: 07-06-2017, 01:35 PM
  4. Can i start my car remotely with android auto?
    Last Post: 07-06-2017, 01:08 PM
  5. Red phone with holographic display
    By Premium1 in forum General News & Discussion
    Last Post: 07-06-2017, 12:52 PM
