1. popcoern's Avatar
    When I run, the watch does not check the pulse
    Is there a way to add it to runtime tests?
    08-01-2017 12:38 AM
  2. amyf27's Avatar
    Not sure if runtime tests, but on Endomondo it will keep track and show your high and low rates. Did you check runtime settings on the watch?
    08-01-2017 05:02 AM
  3. popcoern's Avatar
    Yes and I have not seen it as an option
    08-01-2017 05:11 AM
  4. amyf27's Avatar
    I'll try to take a look at it as well
    popcoern likes this.
    08-01-2017 05:16 AM
  5. popcoern's Avatar
    Thanks
    08-01-2017 05:17 AM
  6. amyf27's Avatar
    I wasn't able to find that app under Samsung Gear
    08-01-2017 05:18 AM
  7. popcoern's Avatar
    So there is no way to do it?
    Can not install another app?
    08-01-2017 07:16 AM
  8. ClintRo's Avatar
    IIRC mine tells me when I should slow down because my heart rate is too fast.
    08-02-2017 09:05 AM
  1. how can i bypass cm applock?
    Last Post: 11-02-2017, 07:33 AM
  2. Why won't my app move to my SD card?
    Last Post: 08-01-2017, 12:38 AM
  3. Replies: 2
    Last Post: 07-31-2017, 11:59 PM
  4. How can to tell if the tex i sent was recoved & read?
    Last Post: 07-31-2017, 11:56 PM
