1. skipatrol's Avatar
    The Samsung Gear S3 uses the top of the case for the antenna. I see reports that a metal band reduced the range and connectivity from what is available with leather or plastic.
    Any insight, confirmation or comments on this? Is it true?
    08-12-2017 04:24 PM
  2. ClintRo's Avatar
    I highly doubt that would be the case. But anything is possible.
    08-14-2017 08:06 AM
  3. jgreg02's Avatar
    I have similar question. As an electrical/electronic engineer, I know that metal bands would change the antenna characteristics some - but just in what way and by how much I can't say. Empirically, I noticed that when outside without my phone, and the Gear was depending on AT&T as well as GPS radio connections, it did not do well with the metal band. I have not tested it in the same place with non-metallic band yet.
    08-16-2017 02:43 PM
  4. jgreg02's Avatar
    08-16-2017 03:19 PM
  5. ClintRo's Avatar
    jgreg... you're repeating yourself... maybe you have been shocked too many times?? LOL :P
    11B1P likes this.
    08-16-2017 04:29 PM
  6. skipatrol's Avatar
    I know. I could not figure out how to delete the second one. I figured somebody would let me know.
    08-16-2017 06:43 PM
  7. MaximilianSi's Avatar
    I've been using metalic bands on my gear s3's, I have both the classic and the frontier, zero problems whatsoever
    08-17-2017 07:21 AM
  8. ClintRo's Avatar
    If you click on the pencil icon I have highlighted below you can edit or delete it there.
    08-17-2017 10:16 AM
  9. jgreg02's Avatar
    Were you using Wi-Fi, Cellular and GPS functions when away from you phone and without active bluetooth connection? I found that around the house it was fine. But outside and away from my phone, it could not pick up cellular or GPS unless I removed the metal band. AT&T cellular where I live has weak signal.
    08-18-2017 01:31 PM
  10. jgreg02's Avatar
    I had tried that multiple times. Edit yes, Delete no.
    08-18-2017 01:32 PM
  11. ClintRo's Avatar
    Maybe you don't have enough posts yet... but I have a delete button at the bottom. Gear S3, metallic V. nonmetallic band-capture.jpg
    08-18-2017 03:38 PM
  12. 11B1P's Avatar
    Clint, you're a "Trusted Member" which is giving you more options.
    08-18-2017 07:21 PM
  13. anon(9602380)'s Avatar
    Mod note. Thread is closed!
    08-19-2017 10:11 PM
  1. Gear S2 and Samsung health
    By AndroiDudeJ in forum Samsung Gear S2
    Last Post: 08-23-2017, 06:40 AM
  2. Gear fit 2 took a **** on me.
    By jpprice14 in forum Samsung Gear Fit 1 & 2
    Last Post: 08-13-2017, 04:41 AM
  3. Why has the rotate function disappeared on my samsung S3?
    Last Post: 08-12-2017, 01:04 PM
  4. Restricted profile on Tab S3
    Last Post: 08-12-2017, 10:06 AM
  5. VIP email notifications on Gear S3?
    By scarnsy in forum Samsung Galaxy S8 & S8+
    Last Post: 08-12-2017, 08:41 AM
