1. KSwan001's Avatar
    When I try to add a credit card to Samsung pay it says to turn on screen lock on gear S3 even though the screen lock os on. I have done multiple factory resets and have been in contact with Samsung and no luck. Any Ideas?
    08-17-2017 12:08 PM
  2. CraesheTurbo's Avatar
    this forum is for gear s. you might want to relocate it.
    08-20-2017 05:05 AM
  3. KSwan001's Avatar
    This is for Gear S3.
    08-20-2017 07:50 AM
  4. Liquidarmz's Avatar
    I am also having this issue
    08-20-2017 12:38 PM
  5. anon(238680)'s Avatar
    Mod Note: Thread moved to correct forum. For future reference, using the Report button (triangle with !), anyone can request a post/thread be moved to a more appropriate forum.
    08-20-2017 12:45 PM
  6. KSwan001's Avatar
    Not sure what I'm doing wrong but I have to be doing something wrong.Why can't I Add a credit card to my Samsung pay on Gear S3-screenshot_20170811-090912.jpg
    08-24-2017 07:54 AM
  7. Mattman86's Avatar
    It appears that you haven't turned on screen lock on your gear.
    08-24-2017 10:19 AM
  8. KSwan001's Avatar
    Screen lock is active on the gear. Anything I do I have to enter a passcode.
    08-24-2017 10:25 AM
  9. KSwan001's Avatar
    Anyone?
    08-25-2017 02:26 PM
  10. monty Stinson's Avatar
    Add card to Samsung Pay on phone, remove app from gear, then reinstall app. worth a shot
    08-25-2017 03:22 PM
  11. KSwan001's Avatar
    Update I removed my phone from Developer mode and now I can add cards. works great.
    09-15-2017 09:35 AM
  12. Michele Aher's Avatar
    You have single handedly saved my sanity with this issue. I have been searching for several days for a remedy to this problem and thankfully I came across your fix. Worked like a charm. Thank you, KSwan001!
    09-25-2017 09:20 AM
  1. Walmart Blocking Samsung Pay For Good!
    By WingLT in forum Samsung Galaxy S7 edge
    Last Post: 11-29-2017, 01:31 AM
  2. Replies: 1
    Last Post: 08-17-2017, 04:55 PM
  3. Anyone help Samsung phone repair Mississauga
    By lucysmithmorgan in forum Samsung Galaxy S8 & S8+
    Last Post: 08-17-2017, 01:12 PM
  4. Why flash doesnt show any effect on pictures
    Last Post: 08-17-2017, 12:05 PM
  5. Why do I no longer receive caller notifications.
    Last Post: 08-17-2017, 11:56 AM
