1. aw113sgte's Avatar
    This is with a Pixel and occurred with my Gear S2 3g and now my Gear S3 frontier.
    The remote connection feature works perfectly for a week or two, typically, then will not remotely connect anymore. I have to do a factory reset on the watch to get it working again.
    I've looked through some old threads and didn't see a solution but it is so repeatable, I figure there must be many others with this same problem.
    I can't pinpoint if it is the watch that fails to connect to the Gear account or the phone. What is different, is now when disconnected from the phone, it will popup a screen that wants me to reconnect bluetooth. This doesn't occur when it succeeds remotely connecting.
    10-04-2017 08:28 AM
  2. anon(463177)'s Avatar
    MY problem is I can connect remotely for text but not for voice. I'm using Digits with an S3 Frontier and an S3 Edge through TMobile. Never got voice to work over 2 weeks of working with tech support.
    10-04-2017 01:46 PM
  1. after factory reset jio will not work?
    Last Post: 10-04-2017, 05:51 PM
  2. "Unfortunately, System UI has stopped." after connected to vpn.
    Last Post: 10-04-2017, 05:44 PM
  3. Why can't I connect to airport Wi-Fi networks? (Pixel XL)
    Last Post: 10-04-2017, 10:46 AM
  4. Samsung J1 not connecting to PNY Duo-Link USB 3.0
    Last Post: 10-04-2017, 06:24 AM
