I had massive problems getting my S3 Frontier to connect for calls. Text and email were no problem. I spend almost a month screwing around with T-Mobile Digit help folks to no avail. Finally, out of the blue, it hooked up. Always figured it was due to some magical switch they threw at TMobile. Apparently thats not the case.
I put a new watch face from GWD on the watch and inadvertently left Debugging on afterwards. Apparently that was all it took! I found this out because, today, I noticed Debugging on and switched it off. Suddenly I couldn't call anymore. Turned it back on and I can.
So if you get a problem making calls on your S3 make sure Debugging is in the ON position. Just a heads up...
