    Walking, running, anything that uses distance totally works, but yoga or any of the other stationary workouts automatically pause unless you are flailing your arm, is there any way to turn off the auto-pause feature? After the Tizen update all answers i have found do not work.
    11-25-2017 09:44 AM
  2. B. Diddy's Avatar
    Moved to the Gear S3 forum.
    11-26-2017 12:09 AM
  3. 11B1P's Avatar
    Go into the workout section, select a program, say walking. Scroll down to Auto-Pause and tap the green line and it should turn to a gray circle.
    B. Diddy likes this.
    11-26-2017 06:43 PM
  1. Why is Samsung Galaxy Tab A using 14.8 GB for system data
    Last Post: 11-26-2017, 12:12 AM
  2. Can't connect Gear 2 Neo
    By Android Central Question in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 11-26-2017, 12:10 AM
  3. My cellphone is connected to wall charger but it shows usb
    Last Post: 11-25-2017, 03:20 PM
  4. Replies: 2
    Last Post: 11-25-2017, 02:34 PM
  5. why is my mobile data oning automatically
    Last Post: 11-25-2017, 12:09 PM
