1. Cowboy8467's Avatar
    I got a new update on my Gear S3 that was about 20mb in size, and the stated purpose is to fix the battery drainage in Tizen 3.0. I'm finalizing the update now, but hopefully it will address some of the issues that people have been having since the big update.
    12-18-2017 11:45 AM
  2. egood71's Avatar
    Still waiting for Tizen 3.0.
    12-18-2017 11:52 AM
  3. Ca_lvn's Avatar
    Great post went into settings click check for update and there it was , I'm getting good battery life already on tizen 3
    12-18-2017 03:05 PM
  4. Cowboy8467's Avatar
    That's the one! I've only had it installed for the last few hours but the battery does seem better. Looking forward to seeing how it does on a full charge.
    Edit: Found an article talking about it.
    https://www.sammobile.com/news/gear-...ry-life-issue/
    12-18-2017 04:58 PM
  5. Ca_lvn's Avatar
    funny it says Canada I'm in the states and that's what I received, thanks for posting
    12-18-2017 05:17 PM
  6. daves221's Avatar
    awesome... thanks for the tip
    12-18-2017 05:29 PM
  7. Ca_lvn's Avatar
    Big Improvement in battery performance with this update
    Day 2 no charge I'm at 70%
    12-19-2017 06:56 PM
  8. stormywaters's Avatar
    Hopefully this successful update paves the way for us carrier model S3 people to get a nice firmware update holiday present.
    12-21-2017 11:39 AM
  9. rinkeedink's Avatar
    Stormywaters.....What setup are running though? Always on display? wifi? Gps? which watchface? thanks!
    12-21-2017 11:39 AM
  10. rinkeedink's Avatar
    I got the update last night in the US too, I checked for it manually though. In 1.5 hours use off the charger today, battery has dropped 5%. Always on display on with the Gsimple12hour watchface, wifi off, gps off, NFC off, obviously, BT on, brightness set to 7
    12-21-2017 11:43 AM
  11. pmccartney's Avatar
    Now, after more than 54hours since last full charge, mine is still at 40%.
    New update out to fix battery drain in Tizen 3.0-screenshot_20171221-144333-1-.jpg
    12-21-2017 01:50 PM
  12. dieselwind's Avatar
    Maybe the carriers will start pushing out their 3.0 updates. I have the verizon version and I am itching to get constant heartrate during workouts.
    12-21-2017 03:44 PM
  13. Jaycemiskel's Avatar
    That sure would be nice!
    12-21-2017 04:30 PM
  14. Cowboy8467's Avatar
    Don't get too excited, much to my frustration it appears as though there is a bug with the heartrate tracker when exercising, where it will get to a certain point and then flatline. Last time I went for a run it said my heart rate got up to 166 and stayed at the exact same point for the following 25 minutes. Before the update my HR would fluctuate but now it seems to be stuck.
    dieselwind likes this.
    12-22-2017 08:37 AM
  15. Cowboy8467's Avatar
    After 3.0
    Attached Thumbnails New update out to fix battery drain in Tizen 3.0-5609.jpg
    12-22-2017 08:45 AM
  16. Cowboy8467's Avatar
    Before
    Attached Thumbnails New update out to fix battery drain in Tizen 3.0-5611.jpg
    12-22-2017 08:47 AM
  17. Doug Moffat's Avatar
    Update or no update I have found that a periodic factory update has substantially increased battery life.
    But beware loss of Samsung health data.
    12-23-2017 07:16 AM
  18. 11B1P's Avatar
    and Samsung pay will need to be set up again.
    12-23-2017 09:49 AM
  19. dieselwind's Avatar
    Before
    Question - do you start an exercise on your S3, or do you let it auto-detect it? I notice when I let it auto-detect it doesn't give me a heart rate reading, which leads to inaccurate calorie burn. I haven't tried manually starting an exercise.
    12-23-2017 10:16 AM
  20. Cowboy8467's Avatar
    I always start them manually so that they start HR tracking and location tracking (in the case of a run) right away.
    11B1P likes this.
    12-23-2017 12:17 PM
  1. S8 Plus Battery Apparently Ventrd
    By ChriRicerockets Rice in forum Samsung Galaxy S8 & S8+
    Last Post: 12-19-2017, 03:14 PM
  2. Nexus 10 cannot connect to home network
    Last Post: 12-18-2017, 08:33 PM
  3. How to transfer multi year calendar from Google to Keyone
    By Fizzarotti in forum BlackBerry Android Phones
    Last Post: 12-18-2017, 11:33 AM
  4. Replies: 1
    Last Post: 12-18-2017, 11:05 AM
  5. How to change Chinese firmware into English ?
    Last Post: 12-18-2017, 10:04 AM
