Got a notification that a software update is available. I'm not really sure if I should download it cause of all the battery drain issues. If anyone is brave enough let me know if it's affecting batt life.
I heard the most recent patch actually fixes the battery issues.Got a notification that a software update is available. I'm not really sure if I should download it cause of all the battery drain issues. If anyone is brave enough let me know if it's affecting batt life.
Saga continues Performed thee total Factory resets per VZW techs and multiple check this setting and this setting. I am only able to run the watch in Bluetooth or StandAlone mode. Cannot Remotely Connect anymore.
VZW says sorry we have done all we can call Samsung.......
Samsung wants to know if there is any physical or water damage. I keep telling them that the watch worked perfect until the upgrade
Samsung wants me to send in the watch for "repair". No love no watch for who knows how long. UGH!!
Does anyone on here have the $5 connected watch plan with numbershare? If so can you find me the plan code by chatting with Verizon?
I use the endomondo app and hadn't actually tried it since the upgrade but did so after reading your message and it loaded up just fine and was able to start/run/end/save a workout without any problems so this isn't an app/update issue. Hope you get it figured out.took the update this am. Performed a RESET on my Gear. BIG issue i am having is that my Endomondo App ( I use this ALL the time) want get past the green startup/splash screen. Uninstalled/reinstalled it sticks at the same point. UGH!
so I updated,and noticed a small hit in batt life. Not as bad as some others have experienced but it's still disappointing. I would say it's about a 8-10% difference depending on usage..
Battery life has been crazy good for me since the update.
Did you factory reset afterwards? I'm seeing about 10% more battery drop...
EDIT: I did a factory reset last night and charged the watch to 100%. As usual, woke up this morning and it is at 89% (before the update it would be at 96%)
