    I have just upgraded to a phone with Android 8.0 Oreo. I factory reset my Gear S3 and connected to the new phone.
    Since then, I can't get vibrations on gmail notifications of incoming mail. Other apps (eg SMS texting) vibrate ok.
    This is frustrating, as without vibrations, the whole point of having a smartwatch is largely gone.
    Am on Tizen 3.0.0.1
    Does anyone know of a fix or work-around? Is it likely to be fixed in a future release?
    Thanks
    03-08-2018 02:27 AM
  2. B. Diddy's Avatar
    I moved this to the Gear S3 forum for more specific traffic.
    03-08-2018 11:53 AM
  3. d483772's Avatar
    Exactly the same problem here. Can't get it to work as well. What a bummer...
    03-15-2018 04:11 AM
  4. bbgpsuser's Avatar
    Am on Tizen 3.0.0.1
    Thanks
    What email app are you using? Is it Google's Gmail app?
    Have you tried a different app like TypeApp?
    03-16-2018 11:22 AM
  5. vader4633's Avatar
    Do you have Gmail set to vibrate on the phone as well. The watch uses the same settings for the phone.
    03-17-2018 01:46 PM
  1. Can no longer get my missed phone calls and my texts no list
    Last Post: 03-08-2018, 12:45 PM
  2. Replies: 2
    Last Post: 03-08-2018, 12:13 AM
  3. Why 2011 edge have no Bluetooth or sync
    Last Post: 03-07-2018, 07:48 PM
  4. There is no star on contacts to add to favorites
    Last Post: 03-07-2018, 06:48 PM
  5. Ringer works, but notifications stuck on vibrate?
    Last Post: 03-07-2018, 12:23 PM
