1. neil123456's Avatar
    Hi all,
    I am looking at getting a gear S3, wanted to know if there are any issues getting second hand?
    I know the Apple watches use to be locked to the apple id they had been signed into.
    Thanks
    04-03-2018 02:36 PM
  2. Jaycemiskel's Avatar
    Hi all,
    Thanks
    As long as they reset it, it should be fine. I sold my T-mobile one when the Verizon version came out, and the person was able to use it just fine.
    04-03-2018 03:54 PM
  3. jgreg02's Avatar
    The carrier LTE models have a non-removable SIM inside and are locked to the carrier.
    04-10-2018 10:15 PM
  4. Nakrohtap's Avatar
    What kind of deal are you seeing for a used one? Are you looking at carrier or Bluetooth? Best Buy marked them down to $269 for the Bluetooth version I noticed yesterday. That sucks the same price I bought mine for about a month ago with price match on Amazon.
    04-13-2018 06:18 AM
  5. jbjtkbw007's Avatar
    Yeah, this part kinda sucks because you can't use it on prepaid. I have AT&T Prepaid with an LTE version of the Samsung Gear S3, and they can't activate it no matter what they try.
    04-13-2018 08:29 AM
  6. frellingfrakker's Avatar
    If you buy a used carrier version S3 but don't activate it will it still work with just Bluetooth or wifi? I've seen good deals on used Verizon models but don't care about enabling LTE.
    04-17-2018 07:18 PM
  7. STARGATE's Avatar
    If you're buying use, take in consideration all the good info from previous posters.
    But also, check the watch personally before buying, connect it to your phone and tested.
    04-18-2018 04:41 AM
  8. frellingfrakker's Avatar
    Thanks, that's why I'm here. So will a carrier version work fine without LTE enabled? I don't need it to work without my phone.
    04-18-2018 05:43 AM
  9. STARGATE's Avatar
    Any Gear S3 from T-Mobile or any other carrier will pair with a Samsung phone from the GS6 up until now without a problem via bluetooth.
    It'll let you answer and make calls and texts, amongst other things.
    For example, my Note 8 has service with Sprint, but my Frontier is the Tmobile version.
    You don't have to have service on your watch to use it.
    04-18-2018 08:24 AM
  10. frellingfrakker's Avatar
    Thank you. I ended up taking the plunge on a refurbished S3 Classic bluetooth non-LTE. Seller has 30 day return policy so I can put it through testing when I get it. I'm very excited to try it out.
    11B1P likes this.
    04-18-2018 10:28 AM
  11. STARGATE's Avatar
    Unboxing pictures!
    Is that one able to make and receive phone calls?
    04-18-2018 10:48 PM
  12. bbgpsuser's Avatar
    Unboxing pictures!
    A bluetooth (non-LTE) version can make and answer calls by using the Bluetooth paired phone.
    STARGATE likes this.
    04-19-2018 03:54 PM
  13. STARGATE's Avatar
    Good deal, enjoy!
    How do you like it so far?
    04-19-2018 06:51 PM
  14. frellingfrakker's Avatar
    It came in yesterday. Beautiful watch and everything seems to be working but too early to fully evaluate.
    11B1P likes this.
    04-24-2018 07:01 AM
  1. Why is my gear s2 battery draining so quick?
    By Android Central Question in forum Samsung Gear S2
    Last Post: 12-21-2018, 06:33 AM
  2. Using S3 and Fit 2 pro at same time?
    By michail71 in forum Samsung Gear S3
    Last Post: 04-04-2018, 01:29 PM
  3. Why is my gear s2 battery draining so quick?
    Last Post: 04-03-2018, 09:36 AM
  4. Galaxy s8+ / Gear 3 Classic / Repeatedly getting messages many months old!
    Last Post: 04-03-2018, 12:39 AM
  5. S3 freezes or screen turns to a fuzzy grey?
    By cre8tivspirit in forum Samsung Gear S3
    Last Post: 04-02-2018, 07:54 AM
