1. jgreg02's Avatar
    Does the AT&T radio need to be set to Always On for numbersync to work, or will Auto work?
    04-04-2018 09:27 PM
  2. Mattman86's Avatar
    Auto works fine.
    04-06-2018 10:55 PM
  3. jgreg02's Avatar
    What software are you using, the internal number?
    What phone are you using? I am on a Galaxy S9+.
    04-07-2018 09:15 PM
  4. Mattman86's Avatar
    I have a Galaxy S8+.
    All I did was follow the steps in the Gear app on the phone when setting up the watch for the first time.
    04-08-2018 06:29 PM
  5. jgreg02's Avatar
    Thanks. Do you have the Mobile Network under Co,nnections set too Auto on/off or Always on?
    04-08-2018 06:57 PM
  6. Mattman86's Avatar
    During the NumberSync setup process, I have it set to Always On. After NumberSync is done, I change it to Auto On/Off.
    04-08-2018 07:47 PM
  7. jgreg02's Avatar
    OK, when a call comes in, and you are near your phone, does it ring on both the Gear and phone or just the phone?
    thanks.
    04-09-2018 09:47 AM
  8. Mattman86's Avatar
    thanks.
    Both
    04-10-2018 08:05 PM
  9. jgreg02's Avatar
    That is what it did on my PRIV with Android 6. so this looks like a Samsung of Android issue.
    thanks
    04-10-2018 10:08 PM
  1. Can I get my android box to reload new firmware?
    Last Post: 04-25-2018, 03:25 PM
  2. Is This Battery Life On Par With Android Oreo
    By Dankees in forum Samsung Galaxy Note 8
    Last Post: 04-07-2018, 05:37 AM
  3. My Asus ZenPhone 3 Zoom cell phone suddenly switches only to voice input
    Last Post: 04-06-2018, 01:37 AM
  4. Questions about upgrading to Android 8.1.0 multiple times, fingerprint scanner oddity
    By thecarlsoncrew in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 04-05-2018, 11:11 AM
  5. Galaxy s7 to s9 .
    Last Post: 04-04-2018, 08:43 PM
