    How can I set the watch to be always on the running app and not go to a blank screen after a few seconds
    Setting the watch to 'always on' doesn't work, as it just shows the timepeice watchface while you are running
    It only shows the running data for a second or s, if you turn "always on", off. Which is far too quick for me to read on a watch with such a tiny font size ( even the largest font )
    Anyone ?
    01-01-2019 02:51 PM
  2. B. Diddy's Avatar
    I moved this to the Gear S3 forum for more specific traffic.
    01-01-2019 04:28 PM
  3. bbgpsuser's Avatar
    What running app are you using? I use Endomondo and the running information is displayed. Only after you exit the app does the watch face take over again.
    01-02-2019 02:42 PM
  1. Replies: 5
    Last Post: 10-21-2019, 11:25 PM
  2. Samsung S6 using data that's switched off
    By Jazzie1111 in forum Samsung Galaxy S6
    Last Post: 01-01-2019, 02:41 PM
  3. Replies: 1
    Last Post: 01-01-2019, 01:54 PM
  4. Why Samsung 5 dropping WiFi only one location
    Last Post: 01-01-2019, 01:47 PM
  5. Samsung Galaxy s6, SM-G920L update processing feild
    Last Post: 01-01-2019, 01:41 PM
