1. WatchUser001's Avatar
    Hello, I start having some problems after I installed new update for my watch. It screen turn on when I move my hand a bit, not only when I turn my wrist. This issue quite annoying especially when you go to sleep and your watch screen just turn on, I had to take it off. Any suggestion or fixes on this problem, cause it worked fine before update?
    03-18-2019 06:48 AM
  2. Del1701's Avatar
    Is the wake up gesture switched on in the advanced settings of the watch?
    03-18-2019 08:48 AM
  3. WatchUser001's Avatar
    Yes it is switched on. I put my watch on charger to recharge, then i turn it off and on, i think it somehow helped it works normal now.
    03-19-2019 04:11 AM
  4. Del1701's Avatar
    Glad you got it working
    03-19-2019 04:27 AM
  1. Home screen redraw with Pie
    By berfles in forum Samsung Galaxy Note 9
    Last Post: 04-09-2019, 08:43 AM
  2. what year will Verizon update the S8
    By filanto in forum Samsung Galaxy S8 & S8+
    Last Post: 03-18-2019, 04:50 PM
  3. chrome shortcuts stop working after downgrade
    By jackfusion in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 03-17-2019, 10:08 PM
  4. Why are notifications &amplification; orher sounds so lowafter update yesterday
    Last Post: 03-17-2019, 08:15 PM
  5. Pop up afs on screen for stylo 4
    Last Post: 03-17-2019, 08:12 PM
