    Are any glass screen protectors compatible with VR? Glass curve elite has bubbles after each use that get worse so I've resorted to an old zagg HD clear wet install made for s8+ but also compatible with 9+. It distorts the image a bit but atleast it works! I wish someone would make one with a notch where gear VR touches it on each end cause these plastic ones just aren't as good for multiple reasons.
    04-19-2018 05:44 PM
  2. mundo472's Avatar
    I don't use the glass protectors (haven't found one that doesn't make the screen look lousy). The film protectors in Gear VR cause the smallest dust mote that got stuck on it during installation to appear in sharp relief. if I were to use the VR often I'd just take it off and go neckid.
    10-02-2018 05:18 AM
  1. Galaxy S8 swipe lock screen
    By Paknwood in forum Samsung Galaxy S8 & S8+
    Last Post: 04-21-2018, 07:33 AM
  2. my nexus 9 is stuck on google screen ?
    Last Post: 04-20-2018, 11:54 PM
  3. GPS losing signal when lock screen is on???? Moto E4
    Last Post: 04-19-2018, 02:17 PM
  4. Gear S Plugin
    By 103Softail in forum Android 8.0 Oreo
    Last Post: 04-18-2018, 09:23 PM
  5. Replies: 1
    Last Post: 04-18-2018, 08:39 PM
