10-07-2016 10:33 PM
91 1234
tools
  1. alyssa keith's Avatar
    hey, i tried what you are saying but it does not work. i guess the only thing i could do is to format it or reset ( the question now is HOW? how to format when its locked? help me guys. please?
    08-19-2013 09:37 AM
  2. Mari19's Avatar
    I have the same problem with my galaxy pocket! HELP!!!!!!!!!!!!!!!!!!!!!!!
    - - - Updated - - -
    08-22-2013 04:55 AM
  3. remopurushoth remo's Avatar
    same to my problem
    08-23-2013 03:33 AM
  4. Angiehop1's Avatar
    I followed your instructions on how to reboot an android phone. I held the down button down and clicked the button on the right at the same time. The green android robot appeared and said "Downloading Do not turn off target!" It's been 30 minutes. Is this suppose to happen or did I completely screw it up?
    Thanks so much for your help!!!
    09-10-2013 08:59 PM
  5. Angiehop1's Avatar
    I was locked out of my Samsung Exhibit 2. I tried holding the down volume button and the button on the right at the same time. The green android robot came on with the following message: Downloading do not turn off target!! At the top of the screen it says ODIN MODE in red letters. The phone has been stuck like that for an hour and it won't do anything else. Does anyone know what that means? Did I completely screw up my phone? Thanks so much!!
    Zanae Blue likes this.
    09-10-2013 09:26 PM
  6. Tammiglenn's Avatar
    mine does not work... help me please
    09-13-2013 02:39 PM
  7. Tammiglenn's Avatar
    i cant go in my google account because the data connection is not on.. so how am i to unlock the phone??
    09-13-2013 02:46 PM
  8. Thunder1020's Avatar
    My friend is locked out of her LG Mytouch Android 4G. We've tried the up+down+power button and that didn't work. How can we reset it?
    09-22-2013 10:30 AM
  9. Elloh's Avatar
    I'm also locked out of my device (galaxy S3 mini) but both my wifi and data connection are off. Therefore, unlocking via email wont work. I do not want to do a hard reset because i dnt wanna loose my contacts which are stored on the fone.
    Does any body have an idea as to how i'll backup ma contacts or how i could unlock my fone.
    HELP! PLssss
    olihana101 likes this.
    10-11-2013 05:15 PM
  10. meosha's Avatar
    it did not work for me either
    10-28-2013 04:03 PM
  11. nene1913's Avatar
    Plz help me
    11-30-2013 10:11 PM
  12. Zanae Blue's Avatar
    Im lost & i dont know wat 2 do i just want 2 get back into my phone😐
    12-07-2013 11:31 PM
  13. mardie john diamante's Avatar
    not working?does not work......
    12-13-2013 05:24 AM
  14. mardie john diamante's Avatar
    please help me i don't know what to do ....the pattern of my Samsung tablet locked....i don't know how to open...please help me.....
    12-13-2013 05:27 AM
  15. wizardman980's Avatar
    ive forgot my pattern password on my galaxy ace2, can you help? please
    01-07-2014 07:49 AM
  16. olihana101's Avatar
    hey i have a samsung galaxy mini and everytime i try to do the volume up and down power button thing it just goes back to where it says too many pattern attempt
    my google account doesnt work for some reason . can someone pls help ?
    01-13-2014 08:24 AM
  17. Basha Malik's Avatar
    locked my Samsung galaxy ace how to open it
    04-06-2014 08:15 AM
  18. Tlanii White's Avatar
    i had forgot my password and it was long and it said that i did it to much times then it won't let me put in my gmail.com
    it's a t.mobile ATandT
    04-14-2014 09:30 PM
  19. Teresa Bragg's Avatar
    I have this android phone that i bought off of ebay it was a new phone and was advertised as an galaxy s3 which it is not at all but is an android but my two yr old locked up and i cant get into it through the google login the model # is I8160 and i cant find much info on this phone is there anyone who can help me i would greatly appreciate it thanks .
    Help my att phone Motorola atrix locked completely it just let's me see my gmail sign it but it can't turn my WiFi on because it only will let me make emergency calls or back to sign in ? I've tryed taking the battery out and sim but nothing the same? Help
    05-24-2014 02:40 AM
  20. shivam sehgal's Avatar
    it is not working
    07-02-2014 10:52 AM
  21. Jabar Salman's Avatar
    my phone pattern &phone google login doesnt work,
    my phone cant open
    07-09-2014 09:13 PM
  22. MaticVelepic's Avatar
    I did it and only some tests and reboot buttons show up, but not wipe data button or something like that.
    07-21-2014 03:51 AM
  23. shalini flower's Avatar
    i need help i do no how to unlock celkon a67 by useing many pattern attempt
    pls help if i enter user email adderss and password
    it saying incorrect email and password
    08-19-2014 01:32 AM
  24. christian del mundo's Avatar
    same here...
    10-03-2014 08:56 PM
  25. leon zac williams's Avatar
    Go to a shop an
    10-09-2014 08:08 AM
91 1234
